Running Dual Mics in Parallel?
  • Thread starter Thread starter Wabatuckian
Wabatuckian
Wabatuckian
Active member
I'm wondering what will happen if I double mic my amp with only a splitter.
Since the new impedance will be the half of the sum of each mic's impedance, I'm sure that'll change the sound -- maybe it'll lo-fi it?
Also, I'm sure the time alignment will be different for each mic if I don't use exact, high-quality duplicates. What effect would this have? A bit of a doubling effect, maybe?
Thanks!
The electrical loading and the acoustic timing are two separate things here.
For two equal passive source impedances in parallel, the equivalent is Z/2, not half their sum. With unequal values it is Z1×Z2/(Z1+Z2), in the simplified circuit model. That alone does not predict a pleasant “lo-fi” sound: the mics also load each other, and you lose independent level control. A bare Y is not a mic mixer; active/phantom-powered models need particular care. Rane explains the output-combining issue here.
The timing difference is mainly about the sound paths to the capsules, not whether the mics are expensive duplicates. Summing two slightly different arrivals from the same speaker can give comb filtering — peaks and notches, rather than a separate double-tracked performance.
If you have two mic inputs, record separately and compare the blend in mono while moving one mic; that keeps balance and polarity adjustments available. Which two mics and input device are you considering?
Know what? I'm an idiot. I knew Z/2 and have no idea what I was thinking there 😳 I've always added the reciprocals of the impedances, and worked out the reciprocal of the result of the answer.
For 4Ω + 4Ω + 8Ω , 2/8 + 2/8 + 1/8 = 5/8, then 8/5 = 1.6Ω
That's extremely embarrassing. 🙄
I have some cheap mics that use TS plugs, and was just going to put two in series to see what it sounded like. Just seeing what I can play with without letting the magic smoke out.
Thanks!
AH, the other hot word in the recording world beside "glue"... . LoFi. A term that everyone throws around as if it's some well defined sound, yet nobody can say what it really means. You've got that Astatic mic. Just plug that it, and you'll get LoFi.
You have two mic inputs. If you want to play with a dual mic setup, just record to two channels and you can play with them any way you want.
Thanks!
Do you only have a single channel of mic inputs to work with?
I'll be honest - I definitely prefer two mics on a cab to one. But it takes a while to get the positioning and phase relationship between the two right, and in practice, for rhythm guitars in particular, more often than not I lean pretty heavily on my "primary" mic, a Shure SM57. And, if you can really get the positioning of that one right (and my process is to first start by getting as good a tone as I can out of that mic, before reaching for a second t flesh it out), you're already gping to be 95-98% of the way there simply by doing two takes and double-tracking your rhythm part.
If you only have a single input to work with, I wouldn't bother with a second mic.
Glue?
The thing to remember is that summing two mics in close proximity introduces tonal changes - the impedance change rarely causes any issue at all. What happens is that the low notes tend to add together with little change and the higher notes progressively either reduce, or add with a changing ratio - so you sort of have a frequency dependent filter. It might sound a bit like a wah wah pedal is in circuit half up and not moving. You could probably produce that sound with EQ, but remember that what is happening is time changes, that produce level changes. EQ produces similar by selective cut or boost at different frequencies. SO - not at all the same process, but a similar result. The two mics will also be in a different place, so are capturing two separate sounds. I suppose, that if you do it, and like the sound - that's good. Me? Never needed or even wanted to try it properly. It happens too often by mistake, and I spend time fixing it, not creating it on purpose.
Thanks guys. I like to experiment. As long as it's not gonna let the magic smoke out, chances are I'll try it sooner or later.
I don't see the point but, if you have two identical mics, taped together so their diaphragms align then the voltage generated by one mic will be almost matched, instant to instant by the other so no net current will flow between them therefore I doubt they will sound much different from the single mic? This theory breaks down a bit because mics are never identical, there will always be minor differences in impedance so "some" cancellation/reinforcement will take place but I doubt it will amount to more than a dB or two at a couple of frequencies. Then, if the pair are placed very near the source, within 300mm say and one mic is slightly closer, that will have an effect. Differences will be greater I would say with dynamics. Transformerless active mics have an essentially resistive source impedance.
Dynamic microphones are also speakers. If you plug one into the other, you might actually hear what’s coming in the one coming out the other. It won’t be an interesting or useful sound, but it does happen. How that might play out in a setup like this I can’t say, but can’t imagine it’ll be good for either capsule.
You wont hear anything. Years ago connecting two mics in parallel was a useful technique for reducing spill, if you used a polarity reverse cable on one of them. If the two mics were close to each other, they cancelled out, but if you sang into just one of them, you’d made a noise rejection system. It worked well as a get out of trouble thing. It needed a bit of EQ to make it sound ‘normal’. He had a regular band with a singing drummer who could not sing that loudly, so two SM58s together, baskets a couple of inches apart, lips to the grill of one of them. Instant noise cancelling mic!
