Chris Shaeffer
Peavey ROCKS!!!!!!!!!!!!!
Gidge said:
rnc compressor 150.00
Hate to be slightly off topic, but....
Gidge, where can you get an RNC for $150? I was just thinking of picking one up. They're $190 direct from FMR.
Thanks,
Chris
i DONT know of ANY "professional" rappers that use ONE mic. i dont use one mic. i would NOT double up the vocals with the SAME mic. IF i did i would add or do something weird to the second vocal track to make it blend but stand out. A LOT of musicians use condensors and then use a shure to do backup vocals. however you DONT have to do what "a lot" of musicians are doing. you do what YOU want to do.I know what I want, but I don't know what I need to get what I want. Please, tell me why you would not use one MIC, I'm planning on using a condenser for my vocals, but a dynamic for the other stuff...? does this add to an effect or give the different vocals more contrast or what I'd like to hear, sounds interesting.
basically when you double your vocal track but you dont say all of the track. only bits and pieces. its sorta like back ground vocals.What are "ad libs"...? is that when you place vocals over parts of vocals for effect...?
without going overboard and too technical a dynamic mic doesnt require the power that a condenser needs. a condenser needs phantom power and some take 9 volts. this link i give you will explain phantom power.This also costs more, if I do this I'll get that dynamic later on after I've got everything. All I know is condenser uses Phantom power, what's the real difference while where at this topic.
i told you about a condenser and dynamic mic. when i said to "run both" i meant both mics i mentioned. without getting to technical a mic algorithim will basically make YOUR mic sound like a DIFFERENT mic. its possible through emulation/simulation techniques.What is a an algorithims, what's it do, run both of what...?
I don't see why I wouldn't feel confortable using a mixer, since I've never used external. My sounds will be a mozaic from Reason and what ever other software I might end up using, plus probably a keyboard aswell...is this a problem?
last of all, Is the compressor worth getting, I feel that it would be better than any program since it seems to be rated high, and what exactly will I do with it besides mastering etc...? Is that it's main and only function?
man you have to watch and experiment and find the best set up that works for you.I'd like to know how they do everything and then do things my way after I've seen different techniques and styles
yes you could. however what if you want to record more than one person at a time? what if someone who is rapping with you just doesnt sound right using your condenser?I'm still not too clear, but couldn't I do ad libs ect, with a condensor MIC by just using algorithims to make it sound like a dynamic MIC...? or is it not that simple?
the best for who? has it been etched in stone and agreed upon by the world that it is the best? OPINIONS.If that compressor is really the best for compressors under a thousand I'll get it even though it's cheap.
matter of preference. i have an issue of electronic musician where they broke down software stuff vs hardware stuff. good and bad exist in BOTH worlds. according to electronic musician may 2001 vol 17,no 5 page 58-60. frequency range makes or breaks digital eq's compressors or filters and other fx units. also with an EXTERNAL unit your adding something in the recording chain which WILL degrade the signal. will you be able to tell? probably not.Is there a software program that's better for doing compresion, or is it better to get a compressor externally?
yep. i also checked out the roland set up. and im saying for the most bang for your buck you cant go wrong with that. an external mixer with pci slot,20 inputs,phantom power,midi in out and through,LOGIC software for sequencing and recording,24 bit 96khz support,24 track playback, 8 in 8 out.Lastly Czar and the rest suggesting other cards have you even checked the Omni studio and seen the great reviews
