sweetbeats
Reel deep thoughts...
I'm trying to figure out if the output of my Ampex 440 electronics modules are balanced or not...these are the same modules as are installed in my MM-1000 as well.
The inputs are balanced because I have the optional bridging trannies installed, but the manual simply states that the outputs are balanced OR unbalanced at 600ohms. Looking at the schematic I can't figure out if the output is truly balanced...the output is on the right hand side of the schematic. There is an output transformer there, but I'm not savvy enough to understand if the output is balanced by default all the time and becomes unbalanced automatically if an unbalanced cable is connected (i.e. an XLR cable with pins 1 & 2 strapped together), or if there is something special needed for the output to be balanced.
I want to know because I have an opportunity to pick up a Tascam LA-80 and an LA-81 for a good deal, but I'm trying to decide if I need the LA-81 at all. They would be going between my Tascam mixer and the Ampex MM-1000 if needed. I don't need to run balanced because my cable lengths are short enough and I can just unplug the input transformers on the Ampex to run unbalanced inputs, but I'd like to maintain the option to run fully balanced if I like the coloration of the input transformers and/or if in the future the MM-1000 needs to be located in a different area from the mixer and monitors since it is a noisy beast...but what of the outputs?? If they aren't balanced then I don't need the LA-81 and I'll have to get creative if I need to relocate the MM-1000. If they ARE balanced then I don't need the LA-81 but it would be good to get it in the package that's being offered in the event that down the road I need to run balanced on the output side.
The deal on the LA-80 and 81 is limited time...HELP!
