Studio Guru
I'm interested in the Mackie Onyx 1640i 16-Channel Premium Analog Mixer with FireWire Interface for my home studio. I need an education on firewire and other alternatives from some of the experts here!
What kind of computer?
I'm pretty sure USB is the future more than Firewire.
--Ethan
I've been using the Mackie Onyx mixers from day one. Started with the older 1640 and last year picked up the 1640i. My first DAW was an old AMD850 Anthlon (old single core) with 2 gigs memory and it worked just fine. Im now running a Intel i7 2600k with 16 gigs memory and it runs fine. Slower pc's with lower memory count will limit the amount of plugins you can run on a mix. You want to get the quickest pc you can afford with at least 7200rpm hard drives (2), one drive for the OS and DAW, the other to record to. And at least 8 gigs of memory. Now the important part !!!! If the new pc has built in "Firewire", make sure it is a Texas Instrument firewire chip !!!! If you cant find a board with a TI Chip, then buy an add on card with a TI chip. Siig makes some great Firewire Cards and they are under $30.
Thank you, Ethan! I'm sure to ask you a lot about acoustic treatment in the future. Can you please tell me the differences between USB and firewire? Is it all the same basic setup of running from the vocal mics and instruments and amps into the mixer, and then running from the mixer to the computer that's using computer software, like pro tools, or is it a whole different thing?
Thanks, Bushmaster! Do you know a rough guess on what I'd be spending for the kind of pc you're recommending?
Short answer: Firewire has had some advantages over USB in the past in terms of sustained transfer rates. But USB has dominated Firewire in the marketplace, and Firewire is disappearing from PCs and laptops. That doesn't mean that a Firewire interface wont work well for you, I'm just saying that they are going to disappear in the future.
But most of the "good quality" interfaces use firewireI wonder why ? So I would find the best interface you can afford along with a descent pc and whatever connection it uses, well, so be it. If your pc doesnt have that connection, buy a $30 card. If it does, your all set !!! Go make some music !!!!
Arguably the two best manufacturers of interfaces are RME and MOTU. Both of them do USB interfaces up to the point where channel count dictates the need for the bandwidth of Firewire.
