E
ecc83
You've just reminded me--in the bottom of my mic box I have an old D202 I used to like a lot--but it suddenly lost all output.
I had a quick look to see if I could get inside to have a look and fix the (assumed) broken solder joint but couldn't see an obvious way in and didn't want to do more damage in a cack handed attempt. Since then, out of sight, out of mind took over and I haven't touched it.
Anyone know how to get inside a D202 without breaking anything in the process?
Found this B...
View Profile
(No subject)
« Reply #1 on: January 29, 2006, 08:40:39 PM »
I have five of these mics (D-202e), but its been at least five years since any of them has needed any work, so this is written entirely from memory.
Its a dynamic mic, so basically its much less complicated than a condenser (which needs impedance changing circuitry). If the capsules are not damaged, then the problem is most likely a connection problem internally.
As I recall, the capsules are mounted on a central rod which runs down to the base of the mic. Loosening a nut on the rod will allow the capsule / circuit assembly to come out the front of the mic body.
To get into it, you have to remove the XLR connector, and then the chrome "fin" piece which holds (or is) the rear entry ports.
DO NOT twist the XLR or fin section while removing. My recollection is that it is easy to break the wires from the circuit card to the connector by twisting them.
As you disassemble it, note that the fin section includes a switch for bass roll off. You may find a wire break right there - maybe caused accidentally by an earlier owner. If so, fix it and reassemble the tail without taking out the capsule / circuit assembly and recheck it. If its working, great.
If there is no break at the switch, take out the capsule assembly carefully and study it. It is only two dynamic capsules and one or two choke coils (on a circuit card), so there can't be much complicated wiring. If the bass isn't working, follow its leads from the capsule to the circuit card and make sure everything is connected (no cold joints)
There really isn't much to go wrong there, so you are probably going to find a bad connection somewhere in the system.
Cordially,
Tom (remember, I haven't had one of these open for many years)
