Milnoque
Resident Curmudgeon
I'm with Goldtopchas. Look to your stings first. They don't need to be old. A fault in the manufacture can cause this problem easily. When I was doing setup work I would occasionally run into this on new strings. This can be true even on high dollar brand names.
Secondly, the lighter the gauge the more difficult it is to achieve great intonation. It's just too easy to pull a really light string out of position mechanically.
Third, I am going to assume that this problem exists only on one or two strings. It's unlikely that Fender forgot exactly where to locate the frets or the nut on your Strat. If you set your action somewhere in the normal range minor problems with your neck adjustment won't pull you off pitch by 10 cents.
Fourth, Try someone else's tuner. Those little guys are excellent but are far from perfect. The problem could be partly there.
