ron-e-g
Member
Those ones? fgonza2 could you reference the picture number? Thanks. I do suspect the MTS-1000 or the ATS 500 on some as I also had some Tascam PW 88AC2 cables. But why they were with the MS16 is beyond me as those units don't work with that recorder ( I thought) because the transport could not be vari. speed controlled.those look like the ones that connect to the Tascam MTS-1000
Can't you deduce what they are for by looking at the back of the deck...?
I mean....of each cable that you have, one end should/would connect to the deck at some point. Based on where/what that is....it should give you an idea what it's for and what would go on the other end.
That top #1 pic....that black connector is what goes to a Timeline Microlynx synchronizer.
that will be picture #1 but you also need the Tascam IF-1000 for that, and it will work, and yes the MS16 you can control capstan speed through a pin on that connector for a synchronizer
I need some help identifying some cables that came with my Tascam MS-16. I suspect some are for synchronizers but what ones? One appears, to even have a Fostex type connector! A couple others are probably for remotely locating the DBX units? See... Picture #7.
My 2p:
#4: betcha that interfaces the MS-16 with an ES-50...open the hood of the ELCO and see if there are any diodes or resistors in there.
Those are my votes.
