P
Pahtcub
Send me the instrumental and the vocal track raw and I will handle it.
. May I make an off the wall suggestion?
I think you may be fighting with your DAW software a bit because Audacity is really designed to be an editor, not a multitracking/mixing package. Yes, they've added on some ability in that direction but it's not the most convenient or intuitive tool.
REAPER is purpose built for what you're trying to do. It's free to try (the trial never expires) and, if you decide you like it, it's only $65 for the full package. I just have a hunch that you might find it easier and more logical to do what you want. There are also hundreds (if not thousands) of users on this forum who can help you out if you have questions.
Glad you're liking Reaper. Audacity is fine as an editor but gets a bit clunky when you try to mix several tracks together.
No, Reaper isn't free forever. After 30 days they want to you buy it. However, the thing is, unlike every other bit of DAW software, Reaper doesn't disable the trial so you can keep on using it. Considering the fact that they are very fair in this and also that the cost to buy it is only $60 (many other DAWs are $300+) I think it's only right to support the Reaper folk and pay the very reasonable cost.
Anyone know why when I record and use words like "you" it makes an echo sound and amplifys it to where it sounds like a squeal.
That simply sounds like you're recording way too hot. I'm pretty sure you need to record at a much lower volume, which will make your vocals come in lower than you're used to. But that's OK. Just turn everything else down too. As has already been said, you can't record too low, only too loud.
No. Forget about increasing anything. Increasing the "db" doesn't make anything clearer. In fact, as you've witnessed, it only increases the chances of making something sound bad.I guess I should lower my recording volume, and just increase the DB to make the sound more clear.
You're too hung up on volume. Record low, mix low, once you're happy with your mix, then you can worry about taking the "finished" product and doing whatever you need to get the overall volume up, but I wouldn't worry about that right now. Get the mix right first, with nothing clipping, or even getting near clipping. The only thing you should be turning up is your monitors, or stereo receiver or whatever you're listening back on.
Ok, that's a different problem. Getting booming "Ooooh's" is most probably a result of either being too close to the mic, or your room itself is the problem.....or both.You're right.
Except my issue atm isn't sound.. it's the plain "echo or boom or whatever" I get when i say the words "to" or "you" no matter what sound level i'm recording. This wasn't happening before, I probably screwed up one of the settings by accident :/.
Maybe it's just the distance and power I was singing before, compared to now.... it's just so frustrating XD. I don't know what causes the sound to just go crazy at these words..
A "squeal" is a lot different than a boom-y sound....... when I record and use words like "you" it makes an echo sound and amplifys it to where it sounds like a squeal.
A couple of things.....
Where in the room are you recording? The corner? The middle? etc...
Are you using headphones when you record? Or is the music coming out of your speakers?
You might have already answered those, but I didn't feel like going back over the 4 pages to find out.![]()
Sounds like feedback, are you sure what you're singing isn't coming out of any speakers? Try turning them completely off.
Maybe it's the way you're singing ...![]()
