D
Deleted member 196982
Guest
Yes, EQ is a tool that's often used, maybe dynamic EQ might work better in some cases. Sometimes adjusting the mic placement on the guitar can help. The thing to keep in mind is what is important here, and it's almost always the vocal that should be pulling the listener in.Thank you. When you speak of cutting low end, are you talking about EQ?
Since the OP did not specify what type of music they are recording, my question is the same but definitely pointed in the solo acoustic singer/songwriter direction.
You didn't ask me, but for singer/songwriter type recordings, I generally do not mix reverb types, but use an IR-based one that creates the "space." Since my recordings are intentionally dry, and given that, unless you're intentionally trying for some huge reverb effect, a person sitting and playing a guitar is pretty close to a single point, so the listener is not (IMHO) expecting to hear the voice bouncing around in one "space" while the guitar is rattling around in another. Doesn't mean you can't experiment with that, but that's me, and my inveterate laziness, I suspect. Once I have my tracks balanced as best possible, some automation and EQ to try and get something that sounds pretty good, I'll start working the compression on each (and there I'll probably choose different settings and emulations). I put my reverb FX on a separate, stereo bus/aux, and control the reverb [sends] of the guitar and vocal separately to that bus, probably with a tiny bit less send of the vocal to keep it slightly more forward. If you want to play around, you can have separate reverb tracks with different length and pre-delay settings, etc., to try and move the depth of the guitar and vocal separately, but, again, from a listener POV, someone sitting in a chair with a guitar and mic in front of them is not a 3D object.
I don't usually double track or multi-mic, but even if I do, the width of the image is pretty tight, e.g., 10 degrees maybe spread, maybe less. I just listened to a track someone posted elsewhere that had two rhythm guitar backings spread wide, with the vocal in the middle, and the guitars weren't really locked in on where the accents or emphasis should be, though they were Ok timing. I could *not* figure out what I was supposed to be listening to!
My 2¢
p.s. to clarify, the dry mix is fairly narrow for s/s - I let the reverb/space on the stereo bus create the wider impression.
