R
roflcopter
i've been experimenting with recording drums using one mic. when i play the result back, pretty much any snare/kick hit is above 0db...my snare is rather piercing and my kick has no front head so i'm sure these are contributing to the problem as well. it sounds terrible...i even have the little gain switch on the mic set to 'low'. and if you move the mic farther away, it sounds...well, far away.
i've found that backing the track off on the mixer just makes for a quieter distorted track. doesn't help.
what can you do to reduce the gain at the mic?
