Input setup
  • Thread starter Thread starter vVShellShockVv
V
vVShellShockVv
Has anyone figured out how to make your input setup for each audio track the same without manually having to go through the mix panel and changing each one manually???:confused:
create either a session template, or a specific I/O setup and load it into each session you want to be that way.
I think that is what you were getting at.
If you hold down alt it will set the same i/o for each track when you change either. If you hold down shift alt cmd it will step up each input one by one...
so track one has input 1
track 2 has input 2 etc.
