Input Echo Delay In Sonar X2 Producer
Devlin Malcolm
When I enable the "Input Echo" for real time playback, it has a delay. I have done research on it and everyone is saying it may be latency or buffer or something but doesn't say exactly how to fix it or the setting to fix this issue.. Please Help.
Thanks
Devlin
If you use software input monitoring there will always be some latency. You can decrease the latency by lowering the buffers in your audio interface's settings, but the more you lower the buffer the more you risk glitches during recording. The usual solution is to use the hardware input monitoring built into your audio interface. What audio interface do you have?
