Inlays and Covers
  • Thread starter Thread starter sjaguar13
sjaguar13,
"Philboyd, that's what I want to do, print 100 CDs. Couple of questions about the equipment, first of all, what Super Image printer do you use, and how do you like it? Do you use the same printer for the inlays? Do you print on paper and cut it down to fit the case? Is there CDs that are printable and pure silver on the bottom? Where do you get those CDs and jewel cases? Do you just use a little shrink wrap bag sealer thing? How much do you charge for the whole package? "
Super Image printers on the lower end used to be modified Epson printers but they're using Canons now. Either way they load a caddy with the CD on it through the rear after you switch a couple of things. The nice thing about them is that 90% of the time they are the regular printer. I got mine from I/O products. http://www.ioproducts.com/
My concept of printing to a CD is pretty simplistic, like the old 45's, because I do a lot of projects and don't like getting bogged down with graphics. Actually it's cause I still don't get Photoshop and Illustrator. Anyway, it still looks good and professional compared to something you stick on.
I/O products sells inkjet printable media (silver or white) that has worked very well for me with only a few returns out of thousands. My cost delivered is around $65 per 100 with jewel cases.
As far as paper is concerned you can spend quite a bit but Hammermill 28lb. color copy works pretty good at no more than $12 per 500 sheets. My wife works with this stuff all the time and thats the setup that is the most bang for buck.
For templates I use Adaptec, but two different versions on two different computers. All you really need is accurate lines to cut (use one of those slicer thingies) imported to a graphics program cause eventually you'll be bringing in the artwork and text separately.
Shrink wrap? oooooh, that's only fun thing in the process.
These guys will take care of you: http://www.ajminc.com/
Get the starter kit.
Philboyd,
So I use the printer to print on the CDs and on photo-white paper for the inlays. Then I cut the inlays, chuck them into the jewel case, and stick them in a bag. I then seal the bag with the shrink wrap thing, and shrink it using the heat gun? About how long does it take to make 100 CDs? If the printer is just a modified printer, can I get something like this, http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=1746654014 or is that a bad idea?
Thanks,
SJaguar13
Hmmm, never saw that sucker before. I'm not so sure it'll work for the long term. Printers can usually handle thick poster paper and such but a CD in a caddy is too wide for the carriage, and that's where they modify them to lift up the proper amount, otherwise the CD's smudge.
How long does it take to make 100 CD's? Too damn long. Still, it's short run production and the client should know he has to pay a premium for it.
You'll need to score the folds of your inserts/inlays so that they look right and that's done with a ruler and industrial razor blade. And a paper slicer from an office supply place will cut the stock in groups of three or so. When you're shrink wrapping stack the CD's in groups of 20 or so and heat all the sides, hitting the edges the hardest with the gun, then there's little to do afterwards.
Capital Communications has a thing where you buy cd's from them, and they print 'em, send em to you , and you burn em. It's like $1.15 each for 500 and like a buck at 1000 and goes down from there.
You're starting to obsess a little too much about "Do It Yourself". Even if you were building a car from scratch, you still buy some of the parts pre-manufactured. You aren't going to go out and mine iron ore and smelt it into steel and tap rubber plants for sap, etc. It just gets ridiculous.
LMFAO!!!!!!
I know where there is some raw plastic he could make the jewel cases from. Unless he wants to synthesize the plastic too.
