junplugged
Taking the slow road
you have 5 drums and 3 cymbals. 8 mics, maybe more but for stereo toms, that's 3 mics, (3 tracks) and for stereo cymbals either 2 overheads or mics on cymbals, or both! (8 tracks or more).
Then let's talk preamps and compressors. 8 channels of pre amp is expensive if you don't wanna, or don't have 8 pre's into your DAW or board.
But they don't have to all be phantom powered if you aren't using all condensors. But then you're mixing types of pre amps, maybe an issue maybe3 not.
Compression, gotta use it to preven the leakage and be able to control the spikes and levels, can't really ride 8 faders and you know the dynamics will be there, so yes, compress. Now, that is a rack of 8 channels of compression, or use your board or DAW, unless they suck or you can't assign that many to the inputs.
Ok, so if I really want 8 to 10 channels/tracks of drum mics, it's gonna get kinda expensive. I don't really want a Nady pre or some other cheap comp when I have gone thru the trouble of individually mic'ing the kit.
This leads me back to a simpler plan to mic the drums. B/c the complex way, we're talking thousands of bucks on gear, and a couple of hundred in cables and mic stands and clips and etc.
Also, if you're not in a room separated from the drums, how ya gonna set up the placement? record, go back and listen then record and th en go bakc and listen 50 times? then have fun trying to get the phase in line....
this isn't gonna happen for most home studios. esp any w/ the drums in the same room as the recorder/recordist, etc. or, if I'm the drummer and the recordist/engineer/producer this ain't gonna fly So simplify.
Over heads, kid, snare. or go mono, w/ 1 over head or room mic and kik and snare. Maybe not tight snare, but up above so the mic also pics up the HH.
Am I making any sense here? How do you folks do it?
