noisedude said:
			Crazydoc - I would say this - resistance increases with temperature which means in theory you COULD melt the reel because the increased resistance would in turn make the mains supply work 'harder'.
I am making sense, I just don't have the physics terminology to explain it any more
For most materials, the resistivity changes with temperature. If the temperature range is not too large, the resistance is a linear function of the temperature, T, and can be expressed as
 R(T)   =  R(T0) * [ 1 + a(T - T0) ]
                   =  R(T0) + R(T0)*a*(T - T0)
where
T0      =  reference temperature (deg Celsius)
           T       =  temperature of interest (deg Celsius)
           R(T0)   =  resistance at reference temperature (ohm)
           R(T)    =  resistance at temperature of interest (ohm)
           a       =  temperature coefficient of resistivity (1/deg Celsius) - (For copper the value is approximately 0.00427)
So, for example, for an extension cord with a resistance of about 1 ohm (I measured mine), if you increased the temperature by 100 degrees Celsius, the resistance would go up to approximately 1 1/2 ohms - not enough to burn it up.
R(T) = 1 + 1*0.00417*100
       = 1.417 ohms
Of course, if you raised the temperature of the cord from 20 to 120 degrees Celsius, the insulation might start melting on its own.
 The point being that the temperature increase from the increased resistance is negligible in this situation.
BTW, I'm finding this thread very helpful. I have only 2 mic cables, each 20 feet long, but I get quite confused trying to tell them apart. Your suggestions above should be quite helpful.
