The Ghost of FM said:
When we look at other machines with more tracks, even in the professional realm of 1" 8 track or 2" 16 or 24 track, tape hiss can still be a very real issue we have to contend with if we don't pay very strict attention to our levels. The use of Dolby A and latter Dolby SR did factor into the equation of many professional studios that had the budgets to incorporate these NR systems onto their recorders. This was especially true and necessary as soon as we are talking about recording something different then straight out rock music that plays naturally at constant loud levels that would allow us to get away without using noise reduction. As soon as we want to record multiple tracks that have more dynamic parts to them, even with these wider format machines, noise and noise reduction systems will still be an issue we need to address.
Cheers!
Ghost, I'm not sure what your actual experience working with these machines is, but I've spent at least the last decade recording almost all my projects on wide track machines up to 1" 8 track, and I honestly would say that noise was not an issue for me, and I'm kinda fussy. (edit: down below, I think I figured out a key difference: IEC1 eq!) Certainly the tradeoff between a little bit of hiss that is barely audible versus the advantages in the quality of sound, lack of dropouts and ease of maintenance and adjustment should be considered. And my projects are not all loud rock stuff, though some of it is. The one project recorded recently for another group was loud and therefore no problem as far as tape noise.
A few years ago, Bob Katz was suggesting that folks who wanted high quality sound for few bucks should forego cheap digital and use quality wide track analog (either 1" 8 or 2" 16 and forego noise reduction). He may have since decided that progress on digital gear makes that a viable choice as long as you watch every detail of the hardware and software you're using and don't do any more processing than is absolutely required.
2" 24 track does need noise reduction because each track has more noise and you have more tracks adding their noise together. Now, I haven't worked with 2" 16 track, but with proper track muting on an automated console, like I did on my 8 track with my little Mackie 1604, I'd think you could keep things in line.
As far as tape goes, I've still got 15 reels of 1" 3M 996 to sell, and I'm asking only $30 a reel for the almost unused reels and $40 a reel for the totally unused ones. If you run 15 ips IEC1 you can keep the high frequency noise down from what you get on NAB and still get about 32 minutes per reel.
Ah, that's right. That's probably a key factor in why I have had less problem with noise than some. The IEC1 eq curve makes better use of the high frequency dynamic range on modern tape. If you still use NAB eq, you get a lot more noise (lower S/N) in the 2K-6K frequencies where our hearing sensitivity peaks. Of course you also have more headroom, but it's probably headroom you don't need in that frequency range and with that darned NAB rec bass boost you have far less headroom where you need it down in the low end. I recommend that you look for a machine that can be set up for IEC1 eq when running 15 ips, whether wide or narrow track.
If you want portable, about the only large format wide track machine out there was the Stephens machine, and those are just about non-existent and parts are made of unobtainium, so you'd have to be braver than I to go that route. Mitch Easter was wanting to sell me his Stephens 16 track, but I just couldn't go that far out. I'm not sure if he ever sold it. But John used pro level unbalanced audio, so you saved the weight of all those input and output transformers. That's also part of why some folks consider them the best sounding decks ever. The transformers are a big part of the sound on those old machines like 3M, Ampex and early MCI. The Stephens decks had a cleaner sound because of the unbalanced audio, so if that's what you wanted Stephens was the way to go. I personally love the transformers in the path on guitar, bass and drum tracks. Most of the Stephens sound was just the sound of the tape. Anyway, a 2" 16 track in a console could weigh as little(!) as 100 pounds, and in a portable two piece rack it could be less, so they were popular in mobile trucks.
There are options for portable, small format, wide track machines. Mitch Easter has a cute little 3M M-23 1/2" 4-track in two portable cabinets that needs head relapping. I'm not sure if he'll ever actually sell it, but I think we had talked about $1000 or so, plus allocating $500 for JRF to lap the heads. The Ampex AG-440 series could be put into a rack, but they didn't have the kind of heavy cast deck plates the 3Ms have and aren't quite as solid and free of flex, so I wouldn't recommend them for portable use as much as the 3Ms.
Ahh, well, probably best to go the 1/2" 8 track route and get dBx type 1 NR. Or you could be a blasphemer like me and record some stuff on a 1/2" 4 track and port it over and record some more stuff on digital.
Good luck and have fun!
Otto
