X
XLR
______
Granted all tuners are not perfect pitch but I've never seen one off more than a penny or two but have seen people off a nickel's worth. I don't understand why would you trust your ear over a tuner.
For about 8 years I had an upright piano and the best tuner I ever came across was this blind guy. He could find his way anywhere and his ears were as good as any electric tuner if not better. He was a mine of interesting info too.
So can we pull this out of this thread and sticky it?
Much to my amazement it actually sounds like a new piano - tune and action just beautiful.
The bill hurt... but it was worth it.
How long does it hold tune...that you can actually use when recording?
but it's a family heirloom and a good piano, so we decided last year to start maintaining it and caring for it much better than we have all these years. For many years it sat in the corner unloved covered in pictures no one every looked at.At $75 a pop...I'm not getting it tuned every few weeks.....
I am a piano tuner/technician. Done it for 35 years and the last 15 or so in Baton Rouge I was doing 3-5 a day 6 days a week.How long does it hold tune...that you can actually use when recording?
I get mine tuned...sounds good for a couple of weeks, and then you can hear it starting to go in spots, and at that point, it sounds OK for playing, but I give up on trying to record with it...so I use a Kurzweil electric instead, which is OK for Rock/Pop.
I ain't playing any Rachmaninoff!
miroslav ..... there are lots of things that can cause a piano to not hold tune ..... loose pins .... sitting in a bad location (not humidity but temp changes) if it's where say, a heater vent blows directly on it or the sun shines on it thru the window and heats it up during the day. That makes the plate expand and contract and knocks it out of tune.
Something else that can cause a piano to not hold tune is a crappy tuner who can't set the pins right.
well humidity is more of a sticking keys issue. It really doesn't mess with the tuning that much.
Ya' know ...... you could probably learn to touch up those unisons yourself. Expect to screw it up the first time and have to have your tuner come in but after a few tries you could probably take care of a string or two.
I have a tuning hammer, and the little rubber wedgies, though they are getting dry, I need new ones - any good source for them?...I've had them for 30 years!
So don't just assume this guy's doing you right unless he's a friend of yours.
well it certainly sounds like he has solid credentials. That's really all you can go by usually.
And I want to be clear I'm not criticizing him per se since I don't know what all he did so it's impossible to know. 900 is not an unreasonable bill to fix up an action and get a piano pulled up to standard.
Multiple tunings is normal for bringing a piano up although I personally don't ease them up, I yank 'em all the way up first time. But it still takes 3 tunings to pull a piano up regardless of which way you do it.
If you're happy with the piano then it's worth 900 easily.
