I need help!
  • Thread starter Thread starter ggaryy1
Well my annalist says that I'm perfectly fine.:laughings:
(:cool:)
Be advised. There's a huge difference between your analist and your analyst. The first tells you to bend over, and the second tells you why you did.-Richie
:laughings: See what happens when you don't use spell check :laughings:
(:cool:)
Just so you understand, you now have a duty. I have typed in an hour a chunk of what
took me 3 years to figure out, helped by the good folks on this board, and every day trial and error. Now your part. You come back here and share what gear worked for you, or not, and in what way. It is a joy when a poster comes back and says, "I used the gizmo and it does just what you said it would. It rocks!."
On the other hand, I'm no guru, so I need you as a check on me. It is a scary thing to recommend that someone spend money. If someone here takes the time to type advice, you need to tell them if you agreed, after you spent hard-earned money. If I am dead wrong, it can be painful for both of us.
Enough for now. Just this- No one ever takes my advice (OK, *almost* never) on one thing. Two less commonly used mics I mentioned above.- AKG D320 and C2000B. The first is old and discontinued. $35-50 or so on dweebay. An excellent all-purpose dynamic mic.The C2000b is about $330 new, but they can be commonly found used for $150 with the shockmount, which you want, because they are good shockmounts, and pricey. With luck, they can be had for less than $100 used. I wish I had had a pair of each of them when I was starting out. Most folks will advise you to start with condensers by Shure, Audio-Technica, MXL, Rode, CAD, SE, Studio Projects, and a few others, but the two mics above have survived the test of time in my humble little studio. They are both great cheap Swiss-Army mics.-Richie
I'm going with an SM57 and the Akg C2000B :)
I'll let you know how i get on for sure and you can even have a listen to the demos when they're done :P :)
Thanks again
But for now, i'm going shopping !
Thanks again
You could do a hell of a lot worse. Let us know how it works out.-Richie
