I need a microphone
  • Thread starter Thread starter BabyfaceMC
Well, actually it's pretty impossible to choose a mic just from a specification. For example, I have a calibrated reference mic I use to check acoustics in theatres--it's darn near perfect in terms of frequency response (and "better" than most of my favourite mics) but it sounds really boring if I try to record anything real with it.
To try and answer your question:
Frequency response is important because it reflects how accurately a mic converts sounds in the audible range to an electrical signal. With really good ears, you can probably hear from about 40Hz to 20,000Hz (though as you get older this top number reduces--and the lower number is more a kick in the gut than real hearing. In theory, the frequency response should be flat but, in the real world, mic designers add in peaks and troughs in the response to make the mic better for its intended use. For example, vocal mics often have a peak designed in in the upper mid ranges because this helps a voice cut through in a mix. However, the same peak could make a violin very screachy!
Impedance is only important if the mic is the wrong impedance for the interface or mixer you want to feed it into. Almost all modern microphones are low impedance (i.e. under 600 ohms) with most somewhere in the 50-200 ohm range. As long as the mic you choose is something like that, you'll be fine. Just occasionally you may see some older mics with a higher impedance and this might need matching--but unless you're buying either a cheap Skype mic or an ancient classic, you should be fine.
Sensitivity is exactly what it implies...how much sound level is required to get a certain electrical output. If a mic is very low sensitivity, you may need a specialist pre-amp to get the best out of it, otherwise you end up running you pre amp cranked way up and adding noise. Again, though, unless you get into fairly exotic mics, most will be in a "normal" range. FYI, condenser mics tend to be more sensitive than dynamic mics.
Polar pattern IS an area where you have a choice and a decision to make. For some uses, an omni mic--on which is equally sensitive from every direction--gives a more open, natural sound. However, in a typical home studio setting, this also means you'll pick up a lot more of the "room", including computer fans, air conditioners and the bus going by outside. For this reason, "cardioid" mics are probably the most common pattern to use--these pick up far more sound from one side than the other, meaning that facing it away from sources of noise (like your computer) rejects a lot of the unwanted background. It also means that, if you room is hollow and boxy sounding, you pick up a lot less of this unpleasantness.
By diaphragm, I assume you mean "small diaphragm" or "large diaphragm". Small diaphragm mics tend to be more detailed and analytical in their sound while large diaphragms are often warmer and smoother sounding. However, a really good small diaphragm can sound nicer than a mediocre large diaphragm and vice versa. Typcially, a large diaphragm mic tends to be the first mic when people are getting started--but, as you go on, you'll likely end up with a mix.
Thank you very much for your complete info! It cleared up some of my doubts.
To sum up and see if I understood:
Impedance: should be 50-200 ohm range (being better if it's closer to 50 or to 200ohm?)
Sensitivity: the higher the better? what's the best range? A condenser mic has a higher sensitivity?
Polar pattern: Cardioid
Diaphragm: Large
Frequency response: 40Hz to 20,000Hz The first figure (40Hz) the lower the better? and what about the second figure (20,000Hz)? is 40Hz to 20,000Hz the best option or it's better 20-20,000?
Do I need to know something else about:
SPL/Peak/Distortion
Noise Level
THANK YOU! :)
There's no real advantage to a specific number but most common mics will be in the 100-200 ohm range these days, with 150-200 being very common. Only worry if it gets much higher than 200. Which it won't unless you buy an unusual mic.
Within reason. Too much sensitivity would make it easy to overload the mic. I don't want to sound insulting but, with the way different manufacturers quote sensitivity differently, it's going to be hard for you to compare. If you stick to a common brand, the sensitivity will be in an acceptable range. Yes, condensers tend to be more sensitive.
Yes, probably if your main need is vocals in a home setting.
Diaphragm: Large
For vocals, yes, likely your best bet.
Frequency response: 40Hz to 20,000Hz The first figure (40Hz) the lower the better? and what about the second figure (20,000Hz)? is 40Hz to 20,000Hz the best option or it's better 20-20,000? [/b]
Yes and no. As I tried to say, the SOUND of the mic is more important than the absolute frequency response--and, without a graph of the peaks and troughs or at least stating something like "+/- 3dB" it's useless. For vocals, super low response isn't important--your voice won't go that low (it's more for kick drums and bass) and you'll end up filtering it off anyhow to avoid rumble and noise.
SPL/Peak/Distortion
Noise Level
Depends on what you want to record. For a standard voice, the max SPL shouldn't mean much but it might be important if you put it in front of a big guitar cabinet. Noise level? Yeah....the lower the better but, frankly, unless it got bad I'd worry more about how it sounds on your voice than simply getting the quietest mic.
To end, as I tried to say before, specs only tell you so much about how the mic SOUNDS. If you stick to reputable brands, the specs will all be okay--but different voices and source material will sound their best with different mics. If you can find a place that actually lets you try them, that's always the best advice of all.
Ok, I understood perfectly :)
So maybe this mic is a good one: Audio Technica AT2035
From what I read, it's a very good brand. The problem that I found is that there is not technical service in my country, so in case the mic gives me problems, I don't know how the guaranty would work.
Audio Technica AT2035:
Designed for critical home/project/professional studio applications and live performance, this side-address cardioid studio condenser delivers exceptional detail and low noise. Equipped with a switchable 80 Hz high-pass filter and 10 dB pad, the AT2035 handles high sound pressure levels with ease. Along with its rugged construction and high-performance specifications, the AT2035 provides an exceptional level of consistency from model to model. It comes equipped with a protective pouch and a custom shock mount.
Large diaphragm for smooth, natural sound and low noise
High SPL handling and wide dynamic range provide unmatched versatility
Custom shock mount provides superior isolation
Switchable 80 Hz high-pass filter and 10 dB pad
Cardioid polar pattern reduces pickup of sounds from the sides and rear, improving isolation of desired sound source
Includes custom shock mount & protective pouch
SPECIFICATIONS
ELEMENT Fixed-charge back plate, permanently polarized condenser
POLAR PATTERN Cardioid
FREQUENCY RESPONSE 20-20,000 Hz
LOW FREQUENCY ROLL-OFF 80 Hz, 12 dB/octave
OPEN CIRCUIT SENSITIVITY -33 dB (22.4 mV) re 1V at 1 Pa
IMPEDANCE 120 ohms
MAXIMUM INPUT SOUND LEVEL 148 dB SPL, 1 kHz at 1% T.H.D.;
158 dB SPL, with 10 dB pad (nominal)
NOISE 12 dB SPL
DYNAMIC RANGE (TYPICAL) 136 dB, 1 kHz at Max SPL
SIGNAL-TO-NOISE RATIO 82 dB, 1 kHz at 1 Pa
PHANTOM POWER REQUIREMENTS 11-52V DC, 3.8 mA typical
SWITCHES Flat, roll-off;
10 dB pad (nominal)
WEIGHT 403 g (14.2 oz)
DIMENSIONS 170.0 mm (6.69") long,
52.0 mm (2.05") maximum body diameter
OUTPUT CONNECTOR Integral 3-pin XLRM-type
ACCESSORIES FURNISHED AT8458 shock mount for 5/8"-27 threaded stands; 5/8"-27 to 3/8"-16 threaded adapter; soft protective pouch
AUDIO-TECHNICA CASE STYLE R5
Anyone knows if the Audio Technica AT2035 mic is good?
There is a lot of difference between AT2035 and AT2020?
Thanks!
