andycerrone
Banned
I need a headphone preamp. Nothing fancy, just something to get the job done and have a clean channel and volume control. Suggestions?
MadAudio said:Before I tell you how great my Oz Audio HM-6 is, I'll just tell you whatever you end up with will be a headphone amp. There's no such thing as a headphone preamp.
Really, I would have thought you'd know the difference by know......![]()
The main reason is that it would be pointless for me to have the headphone amp in my rack seeing as I have both a studio and a control room. And despite the fact that generally I've only used 4 sends to the HM-6, it's a solid unit.andycerrone said:And also, why would you need the 6 channel one when the 4 channel fits in your rack?
whyseye said:We used Presonus HP-4s at work, and have had two fry in the past 6-8 months.....just recording,when suddenly there's a puff of bad-smelling smoke....my old one keeps working...
Bad batch, or change at the factory?
andycerrone said:Haha. Shut up.![]()
All my thinking about getting a new preamp cause a small fruedian slip.![]()
Sweet. Wanna sell one?mshilarious said:I have two Oz HR-4, they are completely bulletproof, although I've never tried to have sex with them![]()
whyseye said:...Presonus HP-4......
andycerrone said:Now with a headphone amp, just plugging in headphones cuts off sound to the monitors, or is there something you'd have to do to turn the monitors down?
RAK said:Nope. The headphone amp doesn't control anything else. What's your setup/signal path? You have to either just turn the monitors down, or route the signal so that it only goes to the headphone amp, and not the monitors.
For example, without knowing your gear or setup, something like:
Monitors going to Main Out L & R
Headphone Amp hooked up to Line Out 1 & 2
Assign signal to Main Out L & R
Bus signal to Line Out 1 & 2
Mute the mains when you don't want it coming out of the monitors.
andycerrone said:I need a headphone preamp. Nothing fancy, just something to get the job done and have a clean channel and volume control. Suggestions?
