I built a tele
  • Thread starter Thread starter JCH
JCH
JCH
El Nacho
The body is built from some poplar that was leftover from a job that I did a few months ago. The top is mahogany veneer. The sides and back are black. The neck is a mystery neck that I bought on ebay. It turned out to be pretty nice. 12" rad 1-5/8ths nut Strat style rout. The tuners, neck plate, output jack, control cover, and the alnico tele neck pickup are all MM. Noname humbucker bridge, with a noname paf spec pu. Tortoise pickguard. This is my first build so I tried to keep it simple and use it as a learning experience. So far so good.
I fit it together last night for the first time so I could drill all of the holes before completing the finish, shielding, wiring etc.. I'm having trouble making myself take it apart.
Awesome work! I take it you've not gotten to play it yet? I'm wondering how the intonation will be.
Way to go!
Thanks man. After it got the fresh set of walmart 10's. I wired up the humbucker, and plugged in through my volume pedal. Crude but effective.
I was anxious to see how well my layout worked. I wanted to get the best angle from the back of the intonation blocks to the holes through the bridge. Everything worked out fine. The neck height is right where I want it. I didn't have to touch the truss rod. Intonation was easy.
That's amazing. When you mentione "mystery neck" I figured you'd be fooling with the angle and depth till the cows came home.
Good for you!
Cool man. How's it play/sound? I wish I had the motivation do build a guitar. But, I'm lazy.......and that's that. :p
If you have a 4 conductor Humbucker in there you might get a push/pull tone or volume pot and try either coil tapping for the single coil/humbucking sounds or series/parallel wiring. Also a 4 way switch adds variety to the sounds as well. I modded a couple Teles I built and I think the series/parallel sounds are my favorites. The Tele in my signature has the coil tap setup for now-its got some kool tones. ;)
PS-that tortiseshell pickguard looks killer on there-really cool!!! :cool:
I'm not sure how I'll wire it yet It's a two wire pickup that I have in it now, but that could always change. I ordered concentric pots so I could have separate volume, and tone controls. If I wanted to split the pup I don't know where I'd put the switch.
From what I can tell it's going to sound great. It plays dreamy.
The Push/pull pots are in the tone or vol. pots-there is a double pole/double throw switch in there that lets you wire it up without any extra swithes or holes drilled in the control plate. See my link for the push/pull pots~
Push/pull pots
Thanks man. I'm familiar With push pull pots, but they're not an option with concentric pots. I bought stuff to wire it up in a few different configs. I've definatly given thought to a split coil setup. I guess I could always drill another hole in the control cover.
Does Noname rhyme with Mogami? I couldn't find a link to their stuff.
Looks professional, good work! I'm looking forward to hearing some clips :)
apl said:
I saw what you typed the first time!!! :p :p :p
I'm tired... Sometimes I think my hands have minds of their own while typing, too... :eek:
Did you ever make any guitars?
I made a guitar once. I was in basic training, friendless, guitarless, and miserable. I HAD to play. It occupied my thoughts constantly. I decided I would figure out how to make a guitar of some kind with what I had available to me. After much speculation (there was plenty of time to think while waiting in line, doing pushups, etc) I decided what to do.
For the strings, I braided my dental floss into three strings, each three strands thick. I then wrapped the strings around my metal drawer, and used pieces of metal from the end of a spiral bound notebook looped once in the string to tighten and tune them. A small hook in the end of the piece of wire allowed it to stay put on the string on the side of the drawer. I tuned it to an open 5th chord and used a metal belt buckle as a slide to play, using my black marker to mark with harmonics the 12th, 7th, and 5th fret on a piece of cardboard I had partially covering the top opening of the drawer.
It wasn't the best guitar in the world, but it was my mint-flavored, three-stringed, belt-buckle-slide, lap drawer, and I loved it. It was easy to play three chord bangers at a modest volume (quite enough to escape detection by the instructors...). Plus everyone though i was totally insane but genius. At least noone ratted me out; they liked to hear me play :).
Anything with dual humbuckers? I have an imitation flying V that I'm considering tearing apart and 'improving' just to have somethin extra to play with.
Thanks everyone. I've got it taken apart now for the shielding, finish etc. I hope to have it back together this weekend. Here's a picture with the templates that I made. I started gathering parts for it about a month ago, but only started on the build last week.
Thurgood said:
I am Wood unfriendly.
:D
I'm not gay either. :p
Nice guitfiddle man. You have way more patience than I do. I', lookin forward to some clips too. Nice work!
