J
jabulani jonny
Hey guys, let me first say that I've got a Furman PL Plus on the way that I'm hoping will help filter any power noise, but here's the issue. I've got a Behringer ADA8000 that connects to a MOTU 896HD by an ADAT optical cable. Both units are plugged into the same halfway decent consumer power strip. My monitors are also plugged into this power strip. I'm getting what sounds like a ground hum, but I thought that if everything was plugged into the same power source that it shouldn't be doing that. I'm thinking the power source is the issue, but I'm wanting to trouble shoot any other possibilities. With only a few variables involved, does anyone have thoughts as to what might be causing the hum. Here's the equipment that I've run and still get the hum.
MOTU 896HD- plugged into power strip
Behringer ADA8000 hooked to 896 through optical- plugged into power strip
Computer- plugged into power strip
2 Wharfedale monitors running balanced cables from balanced output of 896- plugged into power strip
Thx for the help.
Jonathan
Thx for the help.
Jonathan
