WhinyLittleRunt
Member
I just pulled apart all my wiring tonight to try and isolate a buzz I've been getting but have been too lazy to attack. I'm posting it here because of the 388 being the central hub and though I'm sure it probably has nothing to do with it, I figured most of you have computers in your setup at some point in the chain.
The problem was most apparent when I recently got a Drobo (backup hard drive). I noticed that when the device would boot up or wake up, I could hear the hard drives and the whistling i.e.: when your car alternator picks up the radio, through my monitors. It was one of those wtf moments. So I finally took everything apart and started isolating. The 388, as is, with my monitors hooked up and my 8 channels patched to an XLR bay, is very quiet. Then I turned on my audio interface (Firepod). There's the noise. Even inactive, it was producing a nasty buzz. It is patched back and fourth (stereo outs of the 388 to the inputs on the Firepod and the outs of the Firepod patched into the stereo ins on the 388). I can't see any other way to get the audio back into my 388 for listening so that's what I've got. But I don't really remember the thing being that bad in the past. Anyway, moving on I also found that my LCD (older Apple cinema display) created a buzz in the monitors when on. So the speakers (active) are clearly picking up some frequencies somewhere.
So the question is, how do I avoid this stuff? It isn't affecting the actual recorded output that I can tell but it's extremely annoying to listen to if I have the monitoring up somewhat loud. I thought about a power conditioner but that isn't going to help the LCD issue. I'd rather get a rack mount power conditioner just for my rack gear at the least, but not to solve this problem. What are my options?
