mark4man
MoonMix Studios
[sorry to be posting so often lately...but this one's a biggie & needs to be solved in a big way]...
Every time I use VI's from Native Instruments...as Soft Synths...SONAR goes whacky & will not re-open a project after it's been saved & closed.
If I install a single NI Soft Synth...(normally 'Akoustik' or 'Electrik Piano')...I get a 'Looped Tracks' warning, that reads as follows:
When I hit OK...the project DOES open...but that MIDI Track you're seeing disappears, completely...all data is lost.
If I install an NI Soft Synth & OTHER SS's...(for example, onboard SS's like 'TTS-1' or 'Session Drummer')...I'll get the 'SONARPDR.exe NEEDS TO CLOSE ' window...sometimes w/ a ModName unrelated (?) to NI...such as this:
but normally w/ a ModName related to NI...like this:
Now...the big reason I went out & got Komplete5 in the 1st place was to get the h*** away from the use of romplers. Virtual Instruments sound so much better; & play fine on a modern system (when working correctly). But I really don't feel like going out & spending additional cash for a Muse RECEPTOR or Kore2 to solve this problem (not even being sure if Kore2 could)...& the doggone NI samples should stream as advertised anyway.
So...are there any NI/SONAR users out there experiencing this problem ??? Sure would love to get this solved.
Thanks,
mark4man
ADK Pro Audio Core 2 | Intel DP35DP MoBo/Chipset | Intel Q6600 Quad Core CPU | 4 GB SuperTalent DDR2-800 CL5 RAM | Seagate 160 GB SATA II Primary HD | Western Digital 320 GB SATA II Audio HD | Lynx Aurora8 ~ AES16 | Universal Audio UAD-1 | SONAR PE 7.0.1 | WaveLab 5.0.1 | NI Komplete5
Thanks,
mark4man
