PC mics have power and signal on different lines (ring, tip), so you need to block phantom power with a cap. It is easiest to say use pin 3 for power only; you could use a resistor between pin 1 and 3 (because phantom is already fed through a 6.8K resistor), or a zener diode of 5V or so, and connect to ring. It's also good to use a filter cap parallel with a zener. The zener has the advantage of regulating regardless of the power supply or load from the mic.
Then also you need a cap inline with pin 2 and tip.
