jpmorris
Tape Wolf
The old belt was kind of intact but way too loose and inproperly placed so I just cut it. The new belt looks well placed - I could see where the old one used to be and put the new belt there.
I don't know how to start the machine with the cover off because the control pannel is connected with a pretty short cable. I better figure out some way of checking that when I get home - sounds like a good idea.
Ah yes, sorry. I was thinking of the TSR-8 which has the main cover separate from the control panel.
If you can power the machine on, you can test the capstan just by lifting the right-hand tension roller and making sure the capstan shaft turns.
Other possible causes include the pinch roller not gripping properly - though I think you ruled that out, severe back-tension problems (if the tension is loose enough for the roller to go down, the capstan motor will shut off) or possibly the tach roller if the 38 does use one for motion-sensing. I'll have to check the '32 schematics again at home and see if I can figure out how that works.
) and is always very helpfull offered me his 38 as parts, the electronic parts is gone which is why he'd given up fixing it but he is absolutely sure that the capstain is in good working order. He's asking 59£/67€/95$ for it - is that a good price?
