How to EQ Vocal
  • Thread starter Thread starter Crissbmajor
C
Crissbmajor
Hello My Greetings To U All
Am Wyndzybeatz From Ghana
I Am A Sound Engineer
Working In My Studio, Is A home Recording Studio I Been In This Game For About 3 Years,
The problem I Have Been Facing Is To Eq
Properly As Standard Level In The World
Music Forum,
My Vocal Is not Strong When I mix it,
So I will Like Seek For Help, If There
Will Be Any Guide That Can Enable Me,
Am Using MXL 67G And A Realise
That Mic Lack Punches So What Should
I Do Now To Make It better
Thanks Very Much
First off.. Welcome
It's always tough knowing where to start or what to suggest without hearing something.
Once you get five posts you can put up an example here;
Welcome to the MP3 Mixing Clinic.
When you say 'not strong, to me that could mean things besides -or in addition to 'Eq.
We can get into eq' in general. For the most part, it works ('applies) pretty much the same to vocals as it does other things.
A start may be to ask- What are you hearing now that seems to sound out of tone balance?
Without knowing your voice, the song or the mic in question this is a tricky one to answer.
Samples?
If you boost certain frequencies, typically in the mid range, it's usually a good idea to don't boost the same frequencies for other instruments unless they don't happen at the same time. Often it also sounds more musical to cut instead of boosting but there's no rules.
