I
What do you want to use it on, an individual track or the whole mix or something else?
For eq-ing the whole mix you would patch from the Master Out to the eq and from the eq to the 2-track deck.
For eq-ing individual tracks you might put it on the inserts (called ACC SEND/RCV) using TRS to dual RCA cables.
yes,individual track.
so only one cable from eq (tape outs?) to the channel being recorder?
cheers
Well, one cable with two signals on it, a send and a receive. One end of the cable has a TRS, like a headphone plug, and the other end has two RCA plugs. On the eq you don't have to use the "tape" connections since you're not using it with a home system, just connect to the input and output of one channel.
Hosa Stereo 1/4-Inch Male TRS to Dual Male RCA Insert Cable 3.3 ft. | Guitar Center
hi again. so i tried what u suggested and it seems that theres a problem somewhere. the signal seems to pass to the eq and it shows it on the graphics. but it mutes the recording and also the monitor. i cant get the signal back to the tape recorder.
the eq is fine and i checked it with my amplofier. cables are good.
any idea?
thanks
