D
DiamondSea
Hiya folks
New poster here looking for some help. Excuse the long post but its a little complicated...!
I am collaborating remotely on a recording project with my drummer and it is proving more difficult than I thought. I am recording a scratch backing track in my DAW (Reason) and sending my drummer the wav file. My drummer does not have a DAW or a computer but uses a Roland TD27 drum module. While listening to my wav file he is recording a drum track on the TD27 and then sending me a new wav file of his drum track. I then import this into the song on my DAW and try to sync it up. I knew I would have to line up the start of the track to sync as he is not recording into a sequencer. That is ok but a bit cumbersome but helped by my drummer recording a count in that I can later delete. The problem I am having is that the wav file he has created plays back at a slightly slower tempo than the original backing track even though it was recorded by the drummer while listening to the wav file i originally sent him. I can line up the start of the recording but by the chorus it has gone out of time. I have to go in and time stretch (time-shrink?) the drum track to play back in sync. Before you ask- i know the drummer is playing in time with the backing track as he also sent me a recording including the original backing and it sounded perfect. I just can't get it to line up easily with the original backing track in my DAW.
The drums sound great so I think this recording method will work. I just don't know if I am missing something obvious in creating, exporting and then importing the wav files. I am using 16 bit 44 kHz wav file creation and as far as I know the TD27 uses the same conversion.
Is it something to do with sample rates?
Or is the playback that he is listening to for recording at a slightly slower tempo than the original?
Or is it something to do with my DAW auto-stretching and making a mess of it?
Any help appreciated as I am new to digital audio file management??
I know an obvious answer is that the drummer should record into a computer and DAW so it is sequenced to a grid but that may be a while off...!
