how to check phase?
  • Thread starter Thread starter shortedaman
shortedaman
shortedaman
Avid Audio Analyst
how do you check or tell if two or more mics/tracks are in or out of phase?
thanks for your help.
There are a few ways.
1. Zoom in very close to the waveforms of the tracks so you can see the individual cycles. The peaks and dips should match each other, if they are opposite, then inverting the phase on one will correct it, if they are out of line, nudge one track to match the other.
2. Listen in mono and play the two tracks. Toggle the invert phase switch on one track and listen for a change. The one with the most bass response is typically the in-phase choice. When it is out of phase it could sound warbly or like the meat has been taken out.
3. Use some sort of phase scope tool.
Then there is the whole range where polarity is not out, but any of the possible combinations in time arrival from the source -or multiple points of sources that effects phase.
Where there is any arrival time difference it is a given some frequencies are going to be out. It starts in the highs with short delays and works its way down into lower as the time increases.
In the case of one source you keep your mics the same distance, or pick from the range of phase tone combos. In the case of multiple arrival point –a kit for example, it's the same game but you only get to pick one central spot or area between any spaced pair for 'in phase -and for Hass pan' centering for stereo imagining. Everything from either side plays in the phase' land.
Adding in close mics sets up another layer of it. Same game, new variables.
Panning to mono is our tool to check panned mixed stuff in its worst case' playback As well, mixing any of the signals at equal volume gives the deepest combing notches.
The quickie versions----
'How do you tell if a politician is lying?'
You see his lips moving.
'How do you check if two mics are out of phase?'
You see if they're in the same spot.
I have platform shoes. My legs aren't the same length and they keep them in phase :drunk:
