bluesfordan
Member
our basement was converted to a playroom back nearly 50 years ago. It has a drop ceiling and a raised floor, likely 1" slats under plywood with industrial style carpeting. The walls are sheetrock with paneling about halfway up from floor. There are three closets, 2 nearly the same size one being the utility (water and electric panel) the other just storage. There is a larger closet. There are no windows in this room. The ceiling is rather close due to the floor being raised but whatcha going to do? There is a box built around the center beam that divides the ceiling into 2 sections.
I'm in the process of emptying the room, there will be some stuff mostly boxes of paperwork (bass traps
) If my brother follows through with his plan to sell his condo and move back into the house, I'm losing the bedroom I had planned to use.
How awful does a low ceiling affect the acoustics?
) If my brother follows through with his plan to sell his condo and move back into the house, I'm losing the bedroom I had planned to use.How awful does a low ceiling affect the acoustics?
