How much tube it too much?
  • Thread starter Thread starter timboZ
mshilarious said:
it's easier to screw with a tube because there are more parameters. You can change their performance by modifying plate voltage or filament current. Changing bias can alter the sound in a major fashion.
True, but it's been a long time since I've seen a compressor or a mic pre with grid, plate, or load controls on them...and I'm not about to put my old Yaesu linear amp in my signal chain :).
The question was whether there was such a thing as having too many tube devices chained together. If it wasn't a problem for Ellington, Sinatra, (Arlo) Guthrie, Elvis (pre-Costello), or the Beatles, it's not a problem for us. No more than having all transistors in line is a "problem".
Like Fletcher is always fond of saying; what people seem to misunderstand these days, quality tube gear is designed with the attempted goal NOT to color the signal. If there was a major "tube sound", the design was thought inferior.
mshilarious said:
PS My Apple ][ experiments would have been c. 1983-4. By that time one didn't need to write a network protocol, because 300 baud modems were commercially available :p
What, a 110 baud acoustic coupler wasn't good enough for you? ;) :D
Nah, we were just connecting across the room using homemade (what would later come to be called) "modem cables" made out of 4-conductor phone line. No need to convert to analog and back again, just flip the leads for pins 2 and 3 (TX and RX) and throttle the signal via either pin 5 or 7 (I forget which one now). If we wanted to connect over the phone there were acoustic couplers available even in '79-'81. But we never bothered with that until the 300 baud modems became available. But when the Hayes-Stack 1200 came to town, that was heaven, Baby! ;)
G.
I also wonder - what tube pre ya usin?
If its the Behringer Ultragain, the tube is doing you a disservice.
If its a nice Avalon, then it should be okay. Using all tube shouldn't make a difference if you like the sound. period :)
Are you using an all-tube console???? http://www.vintec-audio.de/
Man... if you piped the heat from that console well enough, you could heat your entire studio :eek:
Don't tempt me ;) I've been mulling over a guitar pedal design that combines control of a miniature tube with a modulator circuit that modulates the clean and tube signals (which would potentially contain a massive amount of harmonics). In fact, I like the name "tubular bell" for it :D Way too lo-fi for a mic amp though.
Well, my Hayes COULD be switched down to 110, in case I had to call somebody that was still in the stone age :p
I remember drooling over that! Unfortunately, I was just 12 or 13, and couldn't legally work yet :( I got a job at 14 though, but I wasted all my money . . . I bought a US P-Bass ;)
It does not require a tube console to run hot enough to heat things. I have a large format non-tubed console that never lets my control room get below 65 degrees or so, maybe even 70. Thats with a door that does not have a good seal, and three old windows that are not very efficient either. That is also with very cold temperatures outside. When it hits -10 or so the cold starts to catch up, but then all I have to do is turn on the second half of the console. The bad news is the power bill when I leave it on like that:( In the summer I almost have to turn it off.
I love it! Of course you'll have the disgruntled few who will return it because they thought it could make their guitar sound like Mike Oldfeld :D. But hey, you can't please everybody.
I was going to say that I thought you'd be a bit on the young side for the genesis of the PC revolution. You were just that much more advanced than most kids :).
To this day if I'm stuck on dialup (as I temporarily am here for now :( ), I still insist on an external modem with the LED dashboard to let me know whatsup. Some old habits never die, they just become disconnected ;).
Hell, leave a 1604VLZ on long enough and you can warm your hands over the power supply...I have :).
OK, I think all you circuit engineering types have a wonderful marketing window that's wide open right now... The Green Mixer! 96 tracks of low noise AND low carbon footprint! :p
You line up Carlos Santana and Sheryl Crow as early customers/spokespeople, and you're laughing all the way to the bank in your new Prius. :D
G.
In a back to the future move, germanium transistors are starting to get new consideration for ICs, because the lower forward voltage results in less heat dissipation . . . of course since nobody makes RoHS compliant germanium transistors, or any discrete germanium transistors anymore as far as I know, it would limit their application to pro audio gear, at least on a large commercial scale.
So... those transistors will be on the parts list in my next Behringer purchase then? :D
As for console heating... I've done work with my 24-channel Yamaha on, along with the DAT decks, pre's and monitors, and that room has gotten 10+ degrees hotter with the door closed :)
Like I said, wait till you see the heat that a 10 ffot wide and 5 foot deep console puts out. In the winter the difference between console on and console off is about 40 degrees:D and $70+ dollars of electricity:(
Oh, I can well imagine :)
