Does that mean you disapprove of my tube software?mshilarious said:tube converter, that's going too far![]()
SouthSIDE Glen said:Does that mean you disapprove of my tube software?
G.
fishkarma said:ENIAC (′ē·nē·ak)
(computer science) The first digital computer in the modern sense of the word, built 1942-1945. Derived from Electronic Numerical Integrator and Calculator.
yes answers.com rocks!
Old school, baby!mshilarious said:Your DAW runs on ENIAC? That kicks ass![]()
I never did the Univac, but I did start out on the IBM 370 (later IBM 4341) back in college. Those were the last of the days when computers looked like computerstimboZ said:I use to run one of these back in the day.
http://upload.wikimedia.org/wikipedia/en/5/54/UnivacII.jpg
http://www.gwdg.de/gwdg/standort/museum/ran/ran7/u1100_stu_gr.htm
.Whatmysay said:Seriously what does it sound like? Does each level of tube add to the wide frequency spectrum or just reinforce the same areas of the sound? Could it be your signature tone?
SouthSIDE Glen said:As far as computers and audio, there the start was when my buddy and I designed and built a homemade control interface between the RS-232 port on a TRS-80 Model 1's expansion interface, an ARP 2600, and a Sequential Circuits Model 800 sequencer.
And that tube top.Robert D said:This is the most totally tubular thread ever.![]()
Make sure to wear tube socks while recording.
Don't forget your tube of EZ-Lube....rockgardenlove said:And that tube top.
All of which was way ahead of what we were doing with the Trash, which we were doing around the '79-'81 time period. All we were doing was using the serial interface to send source and/or control voltages to the ARP and the SC800. Control was provided by a homebrew BASIC program we wrote for sending voltages to the 232 port. It was *very* rudimentary, but man was it fun to mess withmshilarious said:The Trash 80, eh? I guess technically I started fooling around with the tone generator on an Apple ][, and I played with speech sampling rountines even though I didn't have the tape deck, just the floppy drive. When we scored the Apple GS, I had a very simple sequencer program for that, you could drag & drop notation and play it back with a small selection of samples, which were much more primitive than the synths of the day (1987). I mean it was nothing like a DX7. I don't recall if it supported MIDI or not![]()
. We later expanded the 232 control engine to the point where we built a "network protocol" (I use the term VERY loosely) where we were able to send messages and data between our 80s (he had one, and I had one) via their 232 ports.timboZ said:A tube amp miced with a tube mic into a tube pre followed by a tube eq and a tube compressor.![]()
SouthSIDE Glen said:MSH put it exactly right. There is nothing special to worry about just because the majority of gear in your signal chain uses vacuum tube technology instead of solid state technology. As long as you have good gain structure in your signal chain, all should be just fine with no more or no less worries about overloading a particular type of coloration than you would if you had no tube gear. OTOH, if you don't keep your gain structure under control, you'll have potential unwanted effects regardless of whether you're using zero tubes or a million tubes.
