B
baw_heed
Hi, I've had a read through a good few posts and I know another newbie question must be a pain but if anyone has the patience to read this I’d be very appreciative.
BACKGROUND
I’m not new to recording but I am new to soundproofing. I have an ideal space in the double garage of my new house for recording – unfortunately it’s next to a road that is busy during rush hours (ok - slightly less than ideal then). There is not outrageous levels of noise (more lots of low level) but enough to hear on a recording (particularly in the wet). There is also a boiler in the garage that tends to have a bit of a click and a rumble from time to time.
ANSWER - Isolation Booth! A big project isolation booth would be ideal. I have a lot of experience of using VO booths and know the effect they have. Unfortunately I don’t have the time or money for such a construction. Also, I’d like to build a semi perm structure that could be moved once my kids decide they want the garage (it’s not glamorous and shows little commitment to recording I know - but it’s the truth).
Therefore my goals are modest – to build a modest isolation booth (prob 2m x 2m) to record acoustic instruments without the external noise disrupting. To that end I want to deaden most external sound and create a relatively decent recording environment inside. I am not looking for a completely dead room and I understand that I’d have to go to extreme lengths to do this. Therefore – this is a practical, not a perfect, solution I’m looking for.
WHAT I’D LIKE TO KNOW
However, before I embark on a massive mission I’d be grateful for advice on the following.
1) Is there anyway I can measure how much soundproofing I’ll need given the levels of noise I’m experiencing? Even if it's just "lots", "some" or "little".
2) I plan on ……………
* constructing the box/booth out of timber and Gyproc Soundbloc
* Double sheets of Gyproc Soundbloc – ie one either side of the timber frame to create a cavity in a mass - air - mass way)
* covering the outside in either Mass Load Vinyl or Sonic Cord. Poss using "Green Glue" but not convinced yet.
* Acoustic foam inside.
* I’ll seal the edges with metal tape.
* I’ll be using a large domestic Double Glazed Window that I know has good sound blocking properties. on one wall. This is big enough to be the door as well (no health and safety officer here
So really two main points – How do I know how much I need to soundproof – and does my current plan sound viable?
Many thanks for your patience.
All the best.
BACKGROUND
2) I plan on ……………
)So really two main points – How do I know how much I need to soundproof – and does my current plan sound viable?
All the best.
Even with NO additional mass in the cavities. OR...the above mentioned...walls, cieling, equipment and people. This will be one freaking heavy unit.
