miroslav
Cosmic Cowboy
Get some XLR to TRS cables...but the adapter is OK too, though it just adds another layer of connections.
Incredible. The first post explained the difference, and the advantage to XLR, clearly and understandably. All the post following just muddied up the water.
Post should have been closed after the first reply.
What if you are using an XLR CABLE but use an adapter to plug into a TRS jack? For instance I am just setting up my studio and I have 4 XLR inputs in the Apogee Ensemble with Preamps. I have 4 other channels with no preamps that use TRS jacks. I have an Avalon AD2022 2 channel preamp that I was thinking to use adapters for in channels 5 and 6 of the Ensemble.
My reasoning is that I already have preamps on channels 1-4 so it's better to put the Avalon into channels 5 and 6.
Since the cable itself is still "balanced" am I good to go with this route or am I being a rookie newb using a TRS adapter between two 2000 dollar pieces of equipment?
In case it matters I am also using Macbook pro, tascam US-2400, Protools 9, (Also still have Logic Studio), AKG 414 (2 each), Shure SM57s, KSM 27, Beta 52, AKG D 112, and a borrowed Presonus Digimax LT 8 channel ADAT pre.
Thanks in advance for your assistance,
-Neal
Incredible. The first response explained the difference, and the advantage to XLR, clearly and understandably. All the post following just muddied up the water.
(Edited to be more accurate. Sorry, 73mgb.)
Stevie B-
I brought this back from the dead on the last post of the previous page. The first two pages of this explained the difference between the two cables. My specific question was about using an XLR cable from my Avalon ad 2022 only using an adapter to utilize a 1/4 jack in channel 5 of my Apogee ensemble. Because I don't want to go from one preamp into another preamp needlessly AND want to utilize all 6 quality preamps at once. You can see my question above and I though admittedly I am learning here, I don't think my question was unreasonable or incredibly stupid. Miroslav has twice your posts and rep power and seems to think my idea is ok. Do you disagree? If so can you explain why?
Thanks,
-Neal
As to "Why?," maybe it's just because he's been around here longer???
Let's try to make some points clearly then:
1. There is no difference at all in audio quality between feeding a balanced line level signal through XLR or TRS connectors (or a mixture of the two.
2. There's no automatic difference between balanced audio (XLR, TRS) and unbalanced audio (TS, Phono). However, unbalanced audio is far more susceptible to electrical interference so balanced is always the one to choose if you can.
3. If you're using a boutique pre-amp, it makes sense to feed this into a line level input without another mic pre amp padded down to handle the hot signal. You may not hear any big difference, but it's just a more sensible way of doing things.
4. To feed from XLR to TRS the best way is to buy or make a cable with the right connector at each end. Yes, you can use adaptors in a pinch but this puts a longer, heavier set of connectors into one of the sockets, increasing the possibility of damaging something.
5. I can't think of a 5.
Bob
As for resurrecting the thread, I am on several forums related to cars, guns, home recording, and guitars. They all have their own quirks but often you are flamed for not searching and finding related threads instead of constantly starting new threads about the same crap over and over... It seems the better route to take but maybe that's just what I am used to from the first couple forums I started using.
