R
RAK
Manufacturer - Shure, Inc
littledog said:That's exactly the point I was trying to make about halfway up the page. Clearly there is a semantic issue here. Rak and I are defining a wide stereo image as one in which the virtual drum kit appears to be wider than the actual real life kit being recorded. For example, the distance between the high hat and the floor tom appearing to be 15 feet, as opposed to the reality of 4 feet.
When NL5 uses the term "widest image", he apparently is referring to a sharp, clear image, not refering to absolute width. At least that's what it seems. There is no question that a widely spaced pair will create a wider stereo image than a coincident pair - that's just common knowledge. Perhaps NL5 should use a better term than "wide" to describe the sharp clear image that he likes from X-Y configurations.
Sounds about right.
When I referred to XY as "tigther" I meant - "sharp" or "clear" ORTF/NOS being slightly less "tight" (near-coincident as opposed to coincident). Something like two mics 6 feet apart - "wide" stereo image, but not as "sharp" or "clear" because of potentinal phasing issues.
I'm not sure where you got that from. i was just trying to understand what he was trying to say. I believe it is just a matter of semantics, as they have suggested......
