Some vocalists and announcers, especially if equalized for more treble,will produce excessive "sibilance" ("S" sounds, concentrated mostly in the upper midrange and treble). In this situation, the limiter would ideally
limit the signal only when high frequency "S" sounds occur. This is possible by inserting an equalizer into the side chain jack.
This application requires the special stereo-to-dual-mono cord mentioned above and an equalizer.
1. Plug the cord's stereo plug into the side chain jack.
2. Plug the stereo cord's ring plug into the EQ's input.
3. Plug the stereo cord's tip plug into the EQ's output.
4. Increase the EQ gain in those bands whose frequencies should trigger
limiting of the signal. For de-essing applications, try equalizer frequencies
in the range of 2 kHz to 10 kHz. Setup for de-essing is quite easy.
With a graphic equalizer, select a frequency (2K for example), and set
up an excessive boost (as much as 12dB). If the chosen frequency is correct,
the excessive gain at that frequency will trigger the compressor
when overly sibilant passages occur. If you are successful, try adjacent
frequencies one at a time to see which frequency gives the best results.
With a parametric EQ, create an excessive boost in the 2kHz - 10kHz
band, and sweep the frequency control until best results are obtained.
Thus, the high frequency "S" sounds trigger program limiting more
readily than the non-"S" sounds.
5. Adjust the Threshold, Ratio, Attack, Release, etc. for the desired degree
of high-frequency limiting. In de-essing applications, it is your goal to
set the attack and release times as fast as possible, so that the sibilant
peaks are eliminated without any audible change in the program
material.
