P
		pasnu
When you guys mix your bass, what are the general eq and compression settings? What other effects do you usually add to the bass? and do you like to side chain?
			For anybody actually responding with numbers:When you guys mix your bass, what are the general eq and compression settings? What other effects do you usually add to the bass? and do you like to side chain?
That's usually how it should go. There are problems with the recording or arrangement if the above doesn't work.I stick a mic in front of the amp and press record. From there, usually nothing. Sometimes, depending on how much presence I want the bass to have, I'll do an EQ notch depending on where it needs to be.
