illsoulprod
Ill Soul Productions
ok im writting this because for the life of me before i got my BCF2000's there was nowhere on the net (and still isn't) anything that told me how to hook up 2-3 of them together so here is a conversation i had with a member from over at gearslutz.com about how he hooked up his 2 BCF2000's. Simple to the point and for pro tools LE 8 so for ya'll and everyone else that needed a helping hand on the net with this here ya go:
Re: BCF2000
Originally Posted by illsoulprod
I just got finished reading the thread on it here and was wondering if you can mayb walk me through setting 2 of the controllers up. what mayb do i hav to buy or might need that isn't mentioned so i can run them in PT LE 8.
thanks man i appreciate any and all help
pedalboy
Hey dude. I run PT 7.3 something on Windows, I imagine the same stuff would apply to PT 8 on Windows - if you're on Mac, well, all bets are off.
The BCF comes with everything you need. Just download the newest drivers off the website when you get them. You connect the buggers over USB (but the computer sees them as a software MIDI port). The instruction manual tells you how to put the BCF2000 in HUI emulation mode - which is what you want. Then you load up Pro Tools, Setup -> Peripherals -> Control Surfaces tab or whatever it's called. Select HUI from the dropdown, pick the first BCF for the in and out ports, make sure 8 channels is selected, then repeat for the 2nd HUI. Hit okay and load up a session - you should be working now. The control surfaces might be reversed, but you can just swap the IO selection in the setup if you need to.
You can't modify the programmable buttons this way, but you do get bank scrolling, play, stop, scrolling forward and back, mute, pan, and record enable. I don't think you can do anything much else, like plugin control or anything.
there ya go ya'll
everything else should be on the net over at the DUC website
Re: BCF2000
pedalboy
there ya go ya'll
