The Hoontech Audio DSP24 with ADC/DAC2000 breakout box. I bought mine from
http://www.buydigital.co.kr/digital/english/products_showcase.htm It arrived safely after a couple of days with all pieces intact and nothing missing. Keep in mind that it was shipped from Korea to Sweden so I think it's quite an accomplishment.
The good things about this card are;
All the I/O you can eat, including S/PDIF
Good sound quality as far as I can tell
Dirt cheap
Converters in the breakout box instead of on the PCI card. Less interference from magnetic fields in the computer.
The downsides of this card are;
Lousy manual, much info on the Hoontech Q&A pages though.
Not too good preamps, use "real" preamps and line in for serious recording. However, this goes for most soundcard I suppose and they're good enough to get started.
May need a good external power supply, I bought a $40 regulated variable DC supply and set it to 14V. This completely took away the digital background noise that some are experiencing with this card. This is due to poor power filtering. Sometimes the graphics card or even PC power supply can cause some interference. The external power supply took away all of this noise.
No W2k or ASIO2.0 drivers. The are on the way but you know how that goes...
I really recommend it but keep in mind that I haven't done any A/B comparisons with other cards. If W2k drivers or ASIO2.0 drivers are crucial for you, wait until they're really out and working before buying the card. I use n-Track so ASIO is irrelevant to me.
Finally, n-Track registration is $55 for the 24bit version. As pointed out, the compressor plug-in is not included but there are five effects included in the registration; Reverb, Echo, Stereo chorus/Flanger, Auto Volume and Pitch shift. However, it uses DirectX plug-ins so I guess you can find freeware compressors somewhere.
/Ola
