kristian
Try
the Yamaha P200. It is an amazingly good stage piano for under $2000. As a long-time piano player, I was very impressed by the authenticity of its sound.
darrin
I did a double-take on the price of
the sl-990, as
the sl-880 is $700, and
the sl-760 is $500. I much prefer synth-weighted for my use, but that is almost too good of a price to ignore...
However, I'm starting to move away from the jv-1010, as the concept of memorizing switch positions and numbers to get to sounds seems a bit cumbersome to me. Besides, I can add the jv-1010 later.
Ozlee
I mentioned the S03 when I started this thread, and it's funny you should bring it up again, as it's rapidly becoming my first choice. 700+ sounds, 61 keys, initial touch and 64-voice poly is tough to beat for $500. What it is lacking is customizability (as in the S30), aftertouch (not a big deal to me), and expandability (jv-1010 takes care of that). The only other negative is the synth action, which is pretty weak, but for $500 I think I can deal with it.
As far as your setup (Yamaha SO3, Roland 1010, Korg
XR-5), you might want to start a bit slower... pick up the S03, then add on the jv-1010 and/or XR5 if you feel limited. Myself, if I felt limited by the S03, I would probably return it and go with an sl-990 and the jv-1010, or upgrade to the S30.
Questions - all
Does anyone know if the sounds in
the Yamaha S03 are the same as those in the S30? Also, can you "tweak" the sounds in the S03? It doesn't have to be real-time. Also, assuming you can tweak the sounds, are there any user banks in the S03 to store these settings?
Finally, does anyone know if the S30 has aftertouch? It's advertised as such, but I tried the keyboard and didn't hear it.
