Home Recording & Audiofanzine
  • Thread starter Thread starter Psycom
gloups....so what you're sayin' is that i'm about to take a technical beating....:eek:
Heh, just be prepared for a very in-depth discussion. Strikes me that it's good this issue came up as it points out the complexities of coming into a new community.
and demonstrates the years of expertise and wisdom contained therein. We must tread lightly grasshopper.;)
Well i'm just wondering if he doesn't agree with what was written, or just how it was phrased...
What was written. It's flat out wrong. Voltage gain isn't the primary purpose of a buffer amplifier on a condenser mic capsule. If it was, you wouldn't need a FET. Or put another way, you wouldn't need an amplifier in the mic at all, just use a mic preamp.
But the capsule is extremely high source impedance, which is another way of saying it only puts out a wee tiny current, which means that if you don't get an amplifier really close to the capsule, you won't have much signal left at all. But the open-circuit voltage is actually rather healthy. So the only thing the capsule FET really needs to do is act as a current amplifier.
That's not to say that is the only configuration of a capsule FET, but it is indeed common. The well-known Schoeps circuit, for example, has the capsule FET in phase-splitter configuration, which is unity (voltage) gain, followed by a PNP pair which is also just another current amplifier (because the source impedance of the FET is still too high to drive adequately long cables).
Why not just strap a BJT on the capsule? Because the input impedance of the BJT is far too low.
Now, do some mics take voltage gain on the capsule FET? Yes indeed, not because it's necessary to get a reasonable level of sensitivity, but in order to minimize noise in the circuit (such that the only major source of noise is the capsule + FET).
Tube mics work a bit differently; often you'll find these in plate follower configuration, which adds quite a lot of current and voltage gain. The reason for this is tube plates are better at voltage gain, and they will be followed by a transformer which swaps the high voltage for more current. Another way to do that is which a cathode follower configuration, which dumps out lots more current (but no voltage gain), but still requires an output transformer (as far as I know, I don't do much with traditional tube mics).
I mean, I hate to be rude, but these articles have the tenor of those that think there are four types of condenser mics: tube, FET, electret, and "regular" :rolleyes:
Why does this matter? Well, because if you're going to get far in audio engineering, at some point you must wrestle with impedance, and that necessarily leads to Ohm's Law, and amplifier concepts . . . screw up the terminology, and you hinder the student's eventual progress. Most people do not need to know what I just wrote, but they do need to understand line vs. mic vs. instrument levels (voltage) and impedance (current), for example they need to understand why plugging a dynamic mic directly into a line input on a converter won't work too well, and these are all related concepts.
Off on vacation now, enjoy reading Harvey's thread! :)
That's what I was gonna say.
'Cept for the vacation part.
:D:D:D
So which is more detrimental to the BBS?
Forum Member 1 said:
The most common type of phantom power is +48v DC. This phantom power is used to charge the diaphragm and plate. It also supplies a small amplifier which boosts the small voltages generated by diaphram movements.
Forum Member 2 said:
lol good one dude but you should relacks lol you can use any mike lol
I was gonna say that too but i was gonna word it more like "I dont know a whole hell of a lot about dem dere microphonie thingies"...
OK ok, you're definitely arguing with the wrong guy. This isn't my area of expertise, So most of what you're saying is over my head:D .Sorry.(but i will read that thread) But you're more than welcome to write an article that we'll put up on the site, and you even can put your signature on it if you like. Same goes for all of you. We're open to contributions from people who know their stuff as long as there's no marketing involved or brand bias.
That's an easy call.
One is part of an intelligent exchange. It's wrong--and yes, that's bad--but as part of an exchange, it can be discussed and corrected. (Like we're doing here.)
The other is dumb gag that got annoying and frustrating after about 14 seconds--and had knowledgeable "heavyweights" ticked off and considering leaving.
I haven't been an active participant on this bbs in a long while but I can see this site could get real interesting again. Keep up the good discussion. Harvey is a wealth of knowledge.
I don't think he was arguing with you, I think he was putting you right. He is correct.
You'll find folks round here are quick to point out small errors in posts. That's what makes this place an invaluable resource and one of the main things the current membership is keen not to see compromised. Most of the regulars here know who the specialists are. You'll work it out.;)
I was able to build and outfit a good studio and saved many thousands of dollars because of the wisdom folks here willingly and unselfishly shared with me and other folks who ask for help.
People here rigorously fact-check each other here in real time, as you can see.
aggressively, even.:D
And you saved thousands on car insurance, too! Right?
Or was that the other thread? :o
