M
Macellomatik
Hello!
I'm new to the forum and I really wanted to thank you all for the interesting infos I've found here!
I'm a complete beginner with home recording but I have some experience with editing and mixing.
I'm writing because I need help clarifying some aspects of home recording related to the "infamous" Titanium HD.
Here is my case:
I am a singer, guitarist and jack of all trades in a metal band, and we are planning to record our music at home.
Our band already worked with some studios and we are planning this new method to reduce the production costs.
What we want to do is digitally compose the drums (DAW + plugins) and then record the guitars and bass with a DI Box, so that we can edit them as "clean" and then reamp them with an audio engineer.
Also, we will not be doing any mixing and mastering because we are trying to achieve a professional level and I'm not good enough yet
Now, being a gamer in my freetime, I recently bought a new PC with a SB X-Fi Titanium HD, that I hoped would be good for both entertainment and recording.... but, as stated in other threads here and elsewhere, it has a few problems, one of all the lack of an XLR interface.
Still, strictly looking at the specs, the SB is a good board and before spending more money I wanted to understand why it is considered so bad (I did read other threads but my doubts remain).
Now my doubt:
We have a mixer (Behringer XENYX X1204USB) that I could use to route the balanced signal from the DI Box to the line-in (RCAs) of my SB.
The SB should have an input rate of 96KHz at 24 bits and that should be good for professional standards (or maybe not ?).
In any case, other audio interfaces I have seen in the same price range record at the same rate, which I think is good enough as it will all probably be downsampled to 16bit/44.1KHz in the end.
So, if I consider 24bit/96KHz to be good, use the mixer to bypass the lack of an interface and use the SB line-in to avoid any Mic-in related issues, is there something more I have to worry about that will make my recording non-professional (apart from my skills obviously
Or maybe something I have overlooked ?
Thanks for your help!
Here is my case:
Now my doubt:
)?Or maybe something I have overlooked ?
