D
deluci
hi. im new at this forum, and by far its the best one ive visited.
my question is about the gain stages in processors and mixers. i have the m-audio omni (delta 66/omni breakout box combo) hooked up to my computer. i just recently recieved the presonus vxp vocal processor, and im confused on where the gain should be set on both. should i set the vxp to a fairly hot signal and high output leval and then a lower setting on the omni mixer to avoid clipping? or the other way around? or should both be set the same? does it matter? i know it may be confusing to understand what im trying to ask, if so ill try to explain better.....
also, anyone with experience with the vxp, share some of your settings, so i can get a clue on what to do with its other fetures( compression, eq,de ess,idss, expander.......i have no idea what im doing)
thanks for all imput
