help with mixer
  • Thread starter Thread starter mm2k5
M
mm2k5
ok when run our stuff through the mixer it is only kinda loud, when we run a stereo through it it is like really loud. Is there something we should be doing to make us louder? turn up more gain than volume? any help thanks
What kind of mixer are you using?
I ask because you will need to reference the level on each channel to 0db using PFL or Solo (whichever it is called on your mixer).
You turn the channel on, turn down the fader for that channel & aux sends, and adjust the gain pot while watching your meter.
Set each to a 0db reference.
Your stereo outputs a 1VRMS line level signal. And it is unbalanced at that. Blanced signals are lower gain than unbalanced, but blanced provides lower noize and sound quality.
Dial in your channels before trying to mix ;)
