Help routing please (VM88)
  • Thread starter Thread starter Musicbreathe
What do you mean by route? I usually hook monitors up to the monitor outs.
From The M1MKII manual:
"Since the M1 Active MKII are self powered, DO NOT connect them to the speaker putput of another amplifier (such as a powered mixer or a hi fi receiver). Connect them only to the line-level outputs of such devices"
So.. where again in the mixer?
most daws have a monitor out on the rear panel.(l/r) this would be the place to connect active monitors.
So you're saying not to connect them to the mixer at all?
Yes connect to the mixer.
There should be monitor out jacks, if there is only one it would be a stereo type (like for a headphone plug with two black rings) in which case you will have to make (or buy) a lead which goes from a TRS plug to 2 RCA type ones (if your monitors use RCA's)
Ask you local electronics shop what you wanna do and they will supply you with the right lead.
Be sure to set monitoring to "stereo".
Hope this helps.
Thanks! Mmm... here's my dilemma one set of outs is +4 dBu (balanced)
THe other oned is -10 dBv (unbalanced and I need +4 dBu according to the speaker's manual but I want it unbalanced...
I'm so confused...
I would like to help but I don't know the difference between unblanced and balanced outs. I have been dying to know though. Someone please explain it to me.
So it's more or less like the microphones?
I'm sorry, I'm a songwriter and this aspect of things is not my forte...
I'm so confused...
Why do you want it unbalanced??
Sorry for the delay, guy I've been doing 10 hour shifts at the job...
I wanted them unbalanced 'cause I thought the speakers didn't have XLR in but they do...
Please, what is a line-level line? Where do I find thsoe in the VM88 mixer...
VM88
I used a lot VM88 last 2 years.We also have active monitors with sub.Now I'm working with VF16, but I use the same outputs.
Well you need to connect your monitors to monitor output ,but turn the knob to the left.Don't use XLR outputs,because you have to keep the master slider too low and you can't use LED indicator.It will show very low level.So connect monitor output to your monitors and don't think why you don't use XLR outputs they are better for connecting to another mixer on stage for example:)
Regards!
nelly
www.popcorn.dir.bg
