EZDrummer3 opinion
  • Thread starter Thread starter OpaD79
I haven't done it often - but it has happened.... where I start a song idea with a drum part, a groove. I love killer rhythm. So why not? It's unusual - but the rules are: there ain't no rules.
I do that a lot with SD. I will get the notes/chords (mainly chords, I'm a chords guy), rhythm, tap out the BPMs to the rhythm, then dumpster dive SD to find a beat/groove I can work with. Build everything off that. Sometimes I start out with the bass (but chords are still driving it) and work with SD.
Yeah I used to do it that way...exactly like you said...dumpster dive for midi/ beat/ groove that fits. But I found it way too frustrating. I did it A LOT like that. Many, many songs. But was rarely happy with the feel. Coz though you find something that matches...it rarely matches well enough. That's why I changed my approach to just finding a groove/ midi clip I like then writing the song/ tune FOR that.
You think it's also a huge step up in realism from EZD/ EZD3? And what do you mean is handles subtle flam notes really well? You mean when you are playing with e-drums/ a midi drum kit? Or you mean that the included midi loops do it better?
I've used EZD, never used EZD3, but was a longtime Superior user and upgraded from 2 to 3. I also program drum MIDI by hand, creating basic loops for the various parts and then cutting them up and editing them to create basic fills.
The two areas where S3 really stepped it up over S2, IMO, is much more realistic responses out of the cymbals, particualrly on repeated hits, and with a much better ability to accurately replicate things like slight ghost notes on the snare or toms or flams, two notes hitting almost but not quite simultaneously. S2 in particular I don't recall sounding terribly lifelike if you fed it two snare hits almost on top of each other - S3 is in a different league, and it sounds like what you'd expect it to if you sat down and did that with a real drum set.
I don't know when I'm going to have the free time to load up both engines and mix down some audio, but I WILL try to get an A/B clip of a Superior 2 and Superior 3 performance of the same MIDI, when I get a chance.
EDIT - oh, but to put a finer pin on it, my hunch here is this; if EzDrummer was an attempt to make the original Superior, I think program a much more of a plug-and-play, user-friendly engine for someone who just wanted to make drum tracks and didn't care about the deep flexibility t offered, and Ez2 was based on S2... then my guess is EzD3 is probably based on the same audio engine as S3, and will probably show the same improvements on cymbals and some of the more subtle snare sounds, just without all the deep-level ability to mix and match kits, decided what bleeds into what else, add or remove various room mics, etc etc. It's not a first-hand informed view, I;m speculating.. but it seems fair.
Thanks. I can vouch for the fact that EZD3 has its fair share of very shotgun-like, robotic rides, hats, snares, kicks etc. Many of them are laughable really. Not to say it's all bad coz some of the midi is ok. But plenty of it is not. I've never had a midi programming game and should start getting into that so I can create more suitable stuff. I think programming a groove or beat bight be inside my capabilities but doing authentic sounding fills would challenge me technically.
I've nearly jumped on Superior Drummer a few times and probably will one of these days. I like the idea of having, as you say, much more realistic sounding cymbals and repeated hit sounds. I wonder if the expansions for EZD3 are of a quality that you could get great results out of them in Superior Drummer 3. Or if the best quality sounds in SD3 are to be had purely out of the SD3 expansions. Coz I've invested cash into quite a few EZD expansions.
At the end of the day (coz I can't play drums and don't have an e-drum kit) it's all about the midi or the quality of the pre-rolled midi or of my skill in making midi. I'll have to start attempting some home made midi/ programming.
I wonder how much of that is the MIDI, rather than the engine, though? I've never used EZD3, so I can't really say how the two compare, but even S2 or EZD if you spent the time on your articulations you could get remarkably good results out of it.
I found SD/EZ to be serviceable with the rhythm and bass filling in so that the drums are just keeping everything glued together. I know when I solo them, they are pretty "straight forward", but with some work, I can get something salvageable.
Having a decent drummer would be a much better option if I had it. I figure if I can work with Bender, I could work with any drummer.
Mostly it is the MIDI. But also the way EZD3 tends to use the exact same sample over and over. Even the variations/ articulations are the same...if there are any noticeable variations in any part. But yeah, the MIDI can tend toward the robotic.
It shouldn't be using the exact same sample over and over again - even the original EzD didn't do that. Maybe look at your humanization settings, and make sure they're, well, on, at all?
Second to that, while even then you should be cycling through a few samples, it probably makes sense to make sure your midi isn't all hitting at the same velocity over and over again.
No I'm literally saying that the sample selections are questionable themsleves. Humanize settings are applied. It will throw in a different snare sample hit if it wants to...but it will be jarring or ham fisted much of the time. And yeah, velocity varying is what I do. It's a machine. There's no way for it to be all it needs to be. I think AD2 puts a little more effort into the sounds and the nature of their midi...the way it is put together. Much of the time. Not always. EZD feels like a computer put them together from a spreadsheet. AD2 does not feel like that as much as EZD.
AD2, EZD, SD.... remarkable technology. I guess I'm just not that particular.
