mshea
It's been a while since I've been here. I was doing pretty well, then my system was attacked by a virus and at 4 years old, I decided I might as well use this as the perfect time to upgrade. Let me give you some background...or you can search through old posts with MSHEA in them and you'll see my progress (or lack of in some cases).OLD SYSTEM:
Gateway
Windows ME
AlesisQS7.1
Event TR5-N Tuned Reference Monitors
Aardvark DirectPro 24/96
Cakewalk Pro Audio 9
Had it all working and talking to eachother for YEARS. Then virus. Then me raiding savings and lots of $$$ later...BIG PROBLEM!!!
NEW SYSTEM:
Dell Dimension8400/Pentium 4 (more than enough juice and guts to run this stuff) (Please note this Dell came with KICK ASS SURROUND SOUND SYSTEM perfect for DVD entertainment which uses an Audigy 2 card. I DON'T WANT TO DISABLE THIS CARD OR IT'S FEATURES IF AT ALL POSSIBLE)
Windows XP Home Edition
E-MU1820
Alesis QS7.1
Cubase VST
I purchased the new computer and initially installed the DP24/96 and expected to be back up and running. WRONG. My old Gateway had 'died' quite a few times and i had installed/reinstalled Cakewalk and everything else with NO problems. I thought it would be the same on a new machine. WRONG!
Issues:
1. DP24/96 interface acting 'possessed' No sound, but could see it monitoring things. Sound, couldn't see monitoring. Sometimes sound through monitors, other times no sound, just glitchy. Thought it was an XP issue, downloaded latest drivers, reinstalled and NOTHING worked. Read a post from a user who switched systems and had exact same issue w/ Aardvark and was NEVER able to resurrect it. Gave up and purchased E-MU1820 (thought problem would be solved)!!! NOPE!
2. NO MIDI signals. NO SOUND through monitors.
What works:
A Line (Mic)
Headphones
Audio from Alesis QS7.1 into E-MU
What doesn't work:
1) No MIDI signals. I don't know if I installed it wrong, if it's the Alesis (beginning to suspect it is) or I need to click some buttons on the E-MU
Connected as follows (MIDI & Audio):
Alesis MIDI OUT to E-MU MIDI 1 IN
Alesis MIDI IN to E-MU MIDI 1 OUT
and
Alesis Left Main to E-MU 1L IN
Alesis Right Main to E-MU 1R IN
(only Audio connection sending signal and sound to E-MU Patchmix DSP interface)
The directions state that when the E-MU is receiving a MIDI signal the 1 & 2 lights under MIDI on front panel will illuminate. They NEVER HAVE!!!
Do i need to be making adjustments in my Alesis??? Do I need to download or install something from/for Alesis onto the new system to get it to communicate or am I missing something in global settings that is different from the Aardvark setup (i've got them plugged up THE SAME!!!) I should have MIDI.
What does the Windows Audio control need to be set to?
Secondly, Monitors were connected to the old DP24/96 using RCA cable going from unbalanced input on back of Monitors to Monitor 5,6 outputs on back of
LOOKS like E-MU needs me to use RCA to 1/4" cable...anythoughts? Does that exist. Can I use the Unbalanced Input 1/4" on the monitors to plug into the E-MU???
There are more oddities. But that's my roadblock ANYONE with similar setup or issues, or knowledge please help.
My GOAL:
I would like to continue using Cakewalk for the bulk of my recording needs while I learn how to use Cubase later. PLUS!!! I have unfinished projects in Cakewalk. So my most immediate need is the Alesis/Cakewalk 9/Windows XP and this E-MU1820 all to play nice together so I can go out and get myself a record deal.
HEEEEEELLLLPPPPPP!!!!
