Y
Yadi
I'm thinking of picking up a copy of ACID 3.0 today. I want to primarily use it to create drum tracks. I use Cubase. Will I be able to import ACID tracks into Cubase?
Yadi said:...Also, last question...Brad? I haven't had time to look at all of the content on the cd, but, in your opinion, could I come up with some pretty convincing (acoustic) drum playing? It's the fills thing that I'm concerned with... I've listened to about 1,000 songs on Acid planet and was only impressed with maybe five.
Also, how difficult would it be to create your own library of loops? I have a roland kit, and could get some good sampled sounds...
Spinsterwun (or anyone) - I could link cubase and acid...at least during the development process? Then, correct me if I'm wrong, I could save the acid as a .wav and import into cubase prior to mix down?
You could surf the net for some "live" drum sounds or go to your local recording studio, and have a drummer play some beats for you. Then, you could save them as WAV. files on CD to use at home.could I come up with some pretty convincing (acoustic) drum playing?
so THIS is what i want to do. i want to press PLAY in ACID and have my xp 60 start up and record the tracks (i would multitrack it)
so THIS is what i want to do. i want to press PLAY on the vs and have ACID play back in sync. all i need is the proper acid settings and im cool.
