C
Chris Meck
Yipes!
A couple of problems, and I've got 1 record in mid-stream and 3 (from folks who want to pay, no less, after hearing some raw tracks) in the wings, and I'm stumped.
First of all, the machine drifted some after the first few sessions, no doubt due to seeing a bunch of voltage after sitting for years (almost dead mint recorder, wasn't used much at all). So I got some De-oxit, I got a 3 tone MRL (100, 1k, 10k) and a multi-meter and went to work.
Quandary no.1: when I got to the EQ adjustments, the manual states that I'm supposed to set 16k to -10db on the machine's meters. Then later in the manual (in the sort of tabled out adjustment checkpoint pages) it says to set 18k to -10db. To add to the confusion, my test tape has only a 10k high frequency tone. So what do I do?
Quandary no.2: Channel 3 is showing proper voltage from the console (Allen & Heath System 8 stepped down to -10 via a patchbay) to the machine; yet the machine is only showing about a 1/3 of the proper voltage at input. Yet it's playback registers perfect on both the 'normal' and 'monitor' heads. This was fine the other day; just started acting up today. Card's properly seated, connections are all fine, tested voltage... Any ideas? Considering cannabalizing another 80-8 with bad heads. Or taking a sledgehammer to it all...
any ideas?
Thanks in advance!!
Chris
well, not really. But I'm close.
any ideas?
Thanks in advance!!
Chris
